That’s encouraging. So maybe it’s just support for the external USB CD/DVD drive that’s causing the problem. I’ll give it a whirl with a USB flash drive.
Out of curiosity: Is there anything -not- working well with your Eee 900 with R1A2?
For me EeePC 900A works just fine with Haiku. Ethernet, sound, native screen resolution - all works. Wifi not tried.
Boots in 10-15 seconds, is very responsive both OS and software. It is really pleasant to use Haiku on such devices.
I’ve been reading a lot on this discussion board and if I have the answer on how you installed Haiku R1A2 on your Eee 900 (I have a 901), it would solve my problem.
My question: How do I install Haiku R1R2 from a successful USB boot (from an anyboot image)? I have an Asus Eee PC 901.
My problem:
I can’t find the installer to start it manually once I’m booted into Haiku via the USB flash disk.
The boot CD made from the ISO hangs on the last icon, and I’ve tried a lot of combination options in the safe mode including disabling all the ACPI’s I could find per http://dev.haiku-os.org/wiki/R1/Alpha2/ReleaseAddendum.
I’m so excited in starting to learn, tinker around and developing apps in Haiku, but I just need it to work on this netbook.
Any direction that will take me one step closer to my goal will GREATLY be appreciated.
Browse the Haiku disk (just do a right-click on it’s icon on the desktop) and
go into Haiku/system/apps, you will find Installer.
or
click the Deskbak’s leaf menu (you know the blue one!), you will find the Installer's shortcut in the “Applications” menu.
