Hello
I would say many thanks you for all works done for revive BEos . and i’ve a question.
I haven’t found how enabled “Num Lock” on boot , for my laptop.
Someone can help me.
Thanks
Hello
Thanks
That’s something that never happened for BeOS. It would take a small program that injects a fake press of the numlock key to turn it on at startup. I don’t know if Haiku has a better way of doing it.
Ok
thank agmsmith
I’m a little surprise , this feature exist on others OS’s
Hi tatoomi,
there was a tiny tool for BeOS by Edmund Vermeulen that apparently still exists: NumLock
The archive contains the source and a version for x86 and ppc. Just put the NumLock_x86 into ~/config/settings/boot/launch and NumLock will be activated on every boot-up.
The best solution would be for Haiku to just remember those key settings when it shuts down…
My enhancement-ticket sense is tingling…
Regards,
Humdinger
hi humdinger,
thank you for link.
I think so the solution is memory those key settings when it shut-down.
Or get it ready-packaged
https://depot.haiku-os.org/#/pkg/numlock/clasqm/1/2/2/-/1/x86_gcc2?bcguid=bc201-UVCM
Even better
Thank michel
