Abaddon crashing on start
(beta 6, x86_84) When starting abaddon, it instantly shows the “The application […] has encountered an error” popup. I don’t know all that much about debugging, how would I go about solving/making a bug report for this issue?
The haikuports issue tracker currently is on github: Issues · haikuports/haikuports · GitHub
It should offer you to generate a report, if you select that, it’ll put a text file on your desktop (It might take a short time till it’s fully written, it should be done after the debugger process has quit).
Create a new issue, give steps to reproduce (crashes on start should be enough for now) and attach the report file
GitHub won’t let me attach a .report file, should I just copy+paste its contents into the github issue?
huh, it should let you do that, there should be a button below the descriptive text.
copy-pasting reports is generally a bad idea as they are just too big. Perhaps leave the report file for now, maybe it’s somehow possible to later attach it
Report made, thanks for the help!
