After a bug in the latest nightly with zsh I checked what the process was switching back to an earlier revision. I found the process to switch back and forth a bit cumbersome so I made a small bash script that lists the nightlies and lets you easily switch with a few keys.
The idea is intereting, however keep in mind that this aproach might conflict with the native one and fill up the state directory if you keep re-downloading the versions instead of using them from old state directories.
To be clear: I suspect this to be a problem, i am not sure of it.
IIRC if the packages are already somewhere in state directories, pkgman should reuse them and only create the txt file. So, it wouldn’t hurt so much.
Wait there’s a native another native method that is not the one described here? I am sorry for the state of confusion, I am really just getting back into this.
All the script above does is get a list of available hrevs and prepare the command as described above .
Chose the right state at boot time. It’s less convenient but usually, problems are fixed in a week or two at max and, you don’t have to do it many times. The problem is that a lambda user may not know what state to chose. For this particular case having hrev indication in the state selector would be better that actual date and time.
