A small Haiku Box almost perfect
Hi all I’m testing my new Haikubox hp 260 g1 CPU i3 intel hd 4400 it’s a wonderful little pc
audio OK
network OK
Hyper-Threading OK
Intel HD 4400 ( Haswell-ULT Integrated Graphics Controller) only vesa 1024x768 32 as the maximum resolution even if my display is capable of 1920x1080 I create a text file using the text editor containing the line ‘mode 1920 1080 32’ but still vesa 1024x768 32
~> listimage | grep -i accel | grep -v grep
1608 0x02039000 0x0203d000 0 0 /boot/system/add-ons/accelerants/vesa.accelerant
~> listdev
device Serial bus controller (SMBus) [c|5|0]
device 9c22: 8 Series SMBus Controller
device Mass storage controller (SATA controller, AHCI 1.0) [1|6|1]
device 9c03: 8 Series SATA Controller 1 [AHCI mode]
device 9c43: 8 Series LPC Controller
device Serial bus controller (USB controller, EHCI) [c|3|20]
device 9c26: 8 Series USB EHCI #1
vendor 10ec: Realtek Semiconductor Co., Ltd.
device 8168: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
device 9c14: 8 Series PCI Express Root Port 3
device 9c20: 8 Series HD Audio Controller
device Communication controller [7|80|0]
device 9c3a: 8 Series HECI #0
device Serial bus controller (USB controller, XHCI) [c|3|30]
device 9c31: 8 Series USB xHCI HC
device 0a0c: Haswell-ULT HD Audio Controller
device 0a16: Haswell-ULT Integrated Graphics Controller
device Bridge (Host bridge) [6|0|0]
device 0a04: Haswell-ULT DRAM Controller
Wonderful that you’re trying out Haiku! You had mentioned the audio, network, and VESA graphics work okay… but are there any other notes you’d want to add? It might help other people who have the same model, or a similar box. And, if you would like me to, I could add this to a list of compatible hardware I try to keep up at http://www.landoftheleaves.org/p/compatibility-list.html or you could use BeSlySAT by lelldorin (more info on this thread: https://www.haiku-os.org/community/forum/new_project_besly_system_analysis_tool_beslysat ).
In any case, good luck with your new box, and have fun with Haiku!
