A replacement for BeShare
As I was playing around with beshare for a little while I was thinking to myself. Maybe a replacement for the currently aging file share platform for haiku where something slightly more modernized i would create the program myself, but like, I said, I’m not much of a coder. In fact, i’ve just started teaching myself the basics of c++ or even an alternative a decentralized to the haiku depot however, that might be a bad idea. When it comes to security but it could provide a platform for people to publish packages without the need of setting up a whole repository these could just create a folder on their desktop or on a partly broken raspberry pi and just fill the folder with haiku packages and people can downloaded and seed it like a torrent i also do apologize if i’ve already made a post like this before which I think I might have
There is already an AI assisted project called HiShare that a lot of us use. It has lots of new features and is very receptive to adding new ones.
Cool can i has link
nvm i have found it
Sorry about that, I should have provided a link. It had also occured to me right after I answered, that you were talking about using it as your own C++ learning project. Don’t let the fact that it is AI assisted deter you from that. You can probably learn a lot by diffing BeShare vs HiShare and understanding what changes were made. Also, while not all human coded projects accept AI assisted code, I don’t know of any AI projects that wouldn’t accept human written code. They will likely run it through AI for further analysis of the code, but that can become a good learning experience as well.
bittorrent with rtorrent or torrentor would be the realistic answer
BeShare isn’t anything like torrenting though. It’s a chatroom with file sharing.
then irc with dcc
BeShare is completely different in experience and I don’t think that would be a good replacement. BeShare allows any user to look at any logged in users shared files and download them. It doesn’t feel like what you are proposing is better, so why not just use BeShare? The protocol is just MUSCLE messages over IP. It’s not like it is hard to make it work.
