A plethora of bugs and crashes
Can you open a ticket for mail failing?
Basically:
launch_roster to stop mail_daemon
the run mail_daemon in a terminal directly and capture its standard output
Then review that for any sensitive info… not sure how much it logs :g, and open a ticket with that reviewed log. It might give a clue why no email is downloded from IMAP
launch_roster stop x-vnd.be-post
/system/servers/mail_daemon
and then launch_roster start x-vnd.be-post when done
What do you mean, where do I get the logs from after doing that? Syslog? I can stop and start the service as much as I want, it doesn’t give me any logs.
The commands to run are at the bottom of my post, you run the mail_daemon directly attached to the terminal, it weill print its output in the terminal and you can copy it.
Launch roster list only sais which services are defined, not which ones run, you can check team monitor to see which system services run (it’s the blue ones at the bottom)
Edit: your issues remind me of a failing hardrive… maybe you can attach a usb drive, format it to bfs and use Installer to replocate your system onto it, if that runs stable (albeit slower) that might confirm that suspicion
Executing it directly works fine for me, now you have me a bit confused, is it possible that the executable bit vanished? :g I don’t see how that could happen with a packaged system though
