I’ve been working on a command-line-tool+, which has been a blessing for myself for the past few years.
It’s based upon Sami Vaarala’s Duktape, however, it’s written from scratch, but still using his library (with a minor addition).
Sami already released the “duk” tool, which is quite useful, however, I found that I had some needs it did not cover. I already have a Linux-version, which does most of what I need. I’ve made a Haiku-build, which has almost everything that the Linux-version has.
I’m able to make both a web-server and a web-client using this command-line tool. Here’s an example, just to give you a taste…
(On Haiku, the “!/opt/bin/duktape” shebang can be replaced by “!duktape”)
Simple HTTP-server:
#!/opt/bin/duktape
try{
var server = new Net.httpServerSocket({})
.listen(null, 11080)
.on(“request”, function(request, response){
if(/^get$/i.test(request.method)){
response.end(“Hello from server\n”);
}catch(e){ File.err(e); }
Simple HTTP-client (a lot bigger):
#!/opt/bin/duktape
var site = "127.0.0.1:11080",
address = Net.resolve(site);
try{
var socket = new Net.socket(),
fragments = [];
socket.eventMask = Events.POLLIN | Events.POLLOUT | Events.POLLHUP | Events.POLLERR;
socket.on("activity", function(socket, events){
if(Events.POLLIN & events){
var fragment = socket.reads(), response, i;
if("string" === typeof(fragment) && fragment.length){
if(!socket.responseHeader){
fragments.push(fragment);
response = fragments.join("");
i = response.indexOf("\15\12\15\12");
if(~i){
socket.responseHeader = response.substr(0, i);
fragment = response.substr(i + 4);
else{
fragment = "";
File.stdout(fragment);
else{
socket.close();
else if(Events.POLLOUT & events){
socket.write(["GET / HTTP/1.0", "Host: " + site, ""].join("\15\12") + "\15\12");
socket.shutdown(socket.SHUT_WR);
socket.eventMask &= ~Events.POLLOUT;
socket.connect(address);
}catch(e){ File.err(e); socket.close(); }
-Here the sockets are event-driven (using ppoll, as epoll is not available on Haiku). For a long time, it was sufficient for me to have blocking sockets only, but if one needs to write a server where two or more clients can connect, it’s a whole lot easier to use events. ![]()
… There’s also a convenience-method for iterating through a directory.
File.forEach(“/path/to/file/w?ldcard.*”, function(pathname, record, search){
File.out("pathname:", pathname);
}, File.DTM_REG|File.DTM_DIR);
“File.out()” will output a newline, while “File.stdout()” will not. Same about “File.err()” and “File.stderr()”.
There is more and will be even more, but I can promise already, that it’s very convenient having this tool; I rarely use bash or perl now …
