I’ve been using Haiku as my sole OS for 9+ months now,
and I wanted to share my experience with you guys.
As for web services, I can do everything that I need,
through a combination of the browsers Web, and Falkon,
For some reason, Web is the only browser my online banking services accept,
I use Falkon mainly for Youtube, and any other intense web sites.
I had stability issues (due to my own fault, memory overclocking),
and my cpu was pegged at all-core turbo speeds,
so I had to disable turbo-core in the bios, it never downclocks,
so if you have stability issues, try disabling turbo and xms/expo and see if that helps.
Now the system uptime has been up to 5 weeks of daily use (24/7 running)
Update from Beta4 to Beta5 went smoothly, network responsiveness was noticably improved.
If I could sum it up in one sentence, it wold be “Less beta than Window98 when it launched”
Thank you to all the developers who work so hard on my new favourite OS,
looking forward to more improvements.
All my systems are now Haiku, Windows and Linux got the boot
Take care /Henrik
