Hi,
I just downloaded the latest nightly of Haiku x64 to port some software a friend is developing and I get a “Panic! 64bit kernel requires a 64bit CPU” message.
Can anyone help?
Thanks,
Zayn
zayn@thinkpad:~$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=17.04
DISTRIB_CODENAME=zesty
DISTRIB_DESCRIPTION=“Ubuntu 17.04”
zayn@thinkpad:~$ uname -a
Linux thinkpad 4.11.0-11.1-liquorix-amd64 #1 ZEN SMP PREEMPT liquorix 4.11-18 (2017-07-20) x86_64 x86_64 x86_64 GNU/Linux
zayn@thinkpad:~$ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 37
model name : Intel® Core™ i7 CPU M 640 @ 2.80GHz
stepping : 5
microcode : 0x4
cpu MHz : 2800.000
cache size : 4096 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 11
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 popcnt aes lahf_lm tpr_shadow vnmi flexpriority ept vpid dtherm ida arat
bugs :
bogomips : 5586.21
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
zayn@thinkpad:~$ apt show virtualbox-5.1
Package: virtualbox-5.1
Version: 5.1.22-115126~Ubuntu~zesty
Status: install ok installed
Priority: optional
Section: contrib/misc
Maintainer: Oracle Corporation info@virtualbox.org
Installed-Size: 163 MB
Provides: virtualbox
Pre-Depends: debconf (>= 1.1) | debconf-2.0
Depends: libc6 (>= 2.15), libcurl3 (>= 7.16.2), libdevmapper1.02.1 (>= 2:1.02.97), libgcc1 (>= 1:3.0), libgl1-mesa-glx | libgl1, libpng16-16 (>= 1.6.2-1), libpython2.7 (>= 2.7), libqt5core5a (>= 5.7.0), libqt5gui5 (>= 5.3.0) | libqt5gui5-gles (>= 5.3.0), libqt5opengl5 (>= 5.0.2) | libqt5opengl5-gles (>= 5.0.2), libqt5printsupport5 (>= 5.0.2), libqt5widgets5 (>= 5.7.0), libqt5x11extras5 (>= 5.6.0), libsdl1.2debian (>= 1.2.11), libssl1.0.0 (>= 1.0.0), libstdc++6 (>= 5.2), libvpx4 (>= 1.6.0), libx11-6, libxcb1, libxcursor1 (>> 1.1.2), libxext6, libxinerama1, libxml2 (>= 2.7.4), libxmu6, libxt6, zlib1g (>= 1:1.1.4), psmisc, adduser
Recommends: libasound2, libpulse0, libsdl-ttf2.0-0, kmod | kldutils | module-init-tools, linux-headers-generic | linux-headers-generic-pae | linux-headers-686-pae | linux-headers-amd64 | linux-headers-2.6-686 | linux-headers-2.6-amd64 | linux-headers, linux-image, gcc, make | build-essential | dpkg-dev, binutils, pdf-viewer, libgl1
Conflicts: virtualbox, virtualbox-guest-additions-iso, virtualbox-ose
Replaces: virtualbox
Python-Version: 2.7
Download-Size: unknown
APT-Manual-Installed: yes
APT-Sources: /var/lib/dpkg/status
Description: Oracle VM VirtualBox
VirtualBox is a powerful PC virtualization solution allowing you to run a
wide range of PC operating systems on your Linux system. This includes
Windows, Linux, FreeBSD, DOS, OpenBSD and others. VirtualBox comes with a broad
feature set and excellent performance, making it the premier virtualization
software solution on the market.
