32bit wine on 64bit teaser
This is just a teaser… and I haven’t done much testing yet to see what works and what doesn’t, but with the help of Claude, I’ve built wine to handle 32bit calls on a 64bit Haiku… without patching the kernel. Instead, made a custom kernel add-on.
Fingers crossed. :slight_smile:
Nice! That’s what I’d love to see, hopefully one day I can play WoW on Haiku. I’ve played on a lot of private servers that only have a 32-bit client, so this is big for me.
Can you send me a link to Wow so I can test it? So far UnrealTournment Windows 32bit works great with nebula, but mouse input is not working 100%. Thanks
Hexen 2 or Uhexen2 would possible too for testing.
Works fine with original Files on Haiku 32bit but Not on 64bit.
The Demo is on 32 and 64bit Haiku Depot.
Demo works on both!
Awesome! I will do some testing when I get home!
My latest wine update now has a fix for nebula driver stack users. I’ve only tested with UnrealTournament 99 with their latest xopengl driver, but wine binds to nebula zink and works pretty good.
Here’s a screenshot showing wine using nebula GPU backend.
While it works, I have found a pretty nasty bug. Haven’t tried to fix yet but how to avoid it is…
  • If the game ask you to restart for new settings to apply, don’t click okay. Just quit the game normally, let wine kill the process and restart the game. If you let the game restart by itself it will crash and freeze up the system.
UnrealTournament “4” on Haiku…well sort of…
My wine port now has working DXVK for real hardware supported video cards.
No hpkgs yet…have to go to bed soon and do some more testing tomorrow.
Will report back soon with updates.
Progress Update…
  • UnrealTournament 99 now runs under dxvk with my Haiku wine port using the D3D11 renderer shipped with UT99 v469. Performance is outstanding.
  • Unreal Tournament 4 also uses dxvk and is now actually playable. I’ll share a demo video later.
  • Found a bug in Haiku Mesa Shader Cache and the Mesa Cache Default Limit of 1G: BFS is reserving extra space when it writes to the cache, causing to falsely inflate, where a 300MB cache, would be reported as 3G, which causing the shader cache in games to hit the 1G limit and fail. This is my best non LLM vetted explanation, though I can’t say it will be enough to submit a ticket, so in my wine port I export a custom mesa cache limit to 100G instead of 1G which suffices for the time being..
  • Currently trying to fix a bug in 32bit prefix auto creation, which has been causing a lot 32bit apps to fail to create full working prefix, and thus fail to load. But progress is looking good.
No new hpkg’s yet… will report back when ready.
Updates
Latest Hpkg for 64bit Haiku Released
  • Fixed wine to be more cpu friendly. Apps like Firefox portable now run a lot smoother
  • Dxvk works with nebula stack and games like UT99 run really well. Here’s live demo video.
  • UT4 loads, and actor motion is possible, but the frame rate is unfortunately too slow. So I would not recommend trying UT4 until a possible update fixes that.
i’m curious can i play starcraft 1 on haiku-wine..
