I have updated yab to 1.7.5.4 This version is available for both x86_gcc2 and x86_64 haiku systems:
http://fatelk.com/repo/packages/yab-1.7.5.4-1-x86_gcc2.hpkg
http://fatelk.com/repo/packages/yab_ide-2.2.8-1-x86_gcc2.hpkg
what’s New`?
yab Version 1.7.5.4
now compiles on x86_64
yab-IDE now updates BuildFactory files on launch
add Window Get Windiwid$, "Minimized-To-Deskbar"
update help files for yab-ide
I’ve been taking a little break from Haiku (the day job and all that) but congratulations on getting this out. X86_64 is clearly the future of Haiku and we yabbers need to be there.
As of hrev51449 yab is broken.
In hrev51449 BControlLook was changed. The unreleased change to yab that added the tabs on the side removed the reliance on BControlLook. So until I get another release done, http://yab.orgfree.com/GetLatest-yab.zip is your friend.
I hope i need just to replace yab and does not need to rebuild anything?
No rebuilding required, just update yab once it is available.
cool thanks bbjimmy
I thoughts lelldorin was the maintainer of yab. Guess when you do so much with it, over the years, that can happen.
FYI the updated yab is available on x86_64.
