I have searched high and low, but cannot find anything relating to problems that may arise by using a RAW partition for my Haiku install.
Could someone enlighten me?
Thank you
Thank you
Hi Arctos,
maybe I misunderstand your issue, but since youâll have to format the partition (âSet up partitionsâŚâ in the Installer) with BFS anyway, it shouldnât matter if or how the partition was formatted before.
Regards,
Humdinger
Thanks for the response, Humdinger.
During the initial installation stage:
I am not really speaking of what was there before.
According to the user guide on Drive Setup, If you plan to use the entire drive as one partition, e.g. a USB stick or a Compact Flash card, you can skip the creation of a partition and proceed right to Initializing.
If you plan to share the drive with more than one operating system, then you need to create the Haiku partition first, and then initialize the partition. In other words, you need to create a partition if you need to have a partition size smaller than the entire drive.
Thanks for the reply.
Ok, so there are no known problems if it is the only os on that drive? Good enough for me.
