Hello! I’m new here.
Just tried out haiku. I like it.
After updating packages (with HaikuDepot) and rebooting i’m unable to connect to wifi.
“Failed to join network. (Incorrect password?)” window
Each time i try to connect to wifi, it asks me for a password.
Each time i input a password and press “OK” the window respawns.
The NetworkStatus seems to update the list of available SSIDs correctly.
The “Network:” field from Network settings menu is changed to default value. (choose automatically) Probably because it updates the SSID list on its own.
Sometimes it’s possible to connect to a network after 10 minutes of pushing ok.
Sometimes there’s no networks found.
Before the update system could automatically connect to my access point on the start of the system, and remembered the password.
I’m running a thinkpad x201t.
The wifi card i’m using is Intel Centrino Advanced-N 6300.
Haiku version: R1/beta3 (revision hrev55181+67) x86_64
~> ifconfig
loop Hardware type: Local Loopback, Address: none
inet addr: 127.0.0.1, Mask: 255.0.0.0
inet6 addr: ::1, Prefix Length: 128
MTU: 16384, Metric: 0, up loopback link
Receive: 0 packets, 0 errors, 0 bytes, 0 mcasts, 0 dropped
Transmit: 0 packets, 0 errors, 0 bytes, 0 mcasts, 0 dropped
Collisions: 0
/dev/net/ipro1000/0
Hardware type: Ethernet, Address: f0:de:f1:5a:be:df
inet addr: --, Bcast: --, Mask: –
MTU: 1500, Metric: 0, up broadcast
Collisions: 0
/dev/net/iprowifi4965/0
Hardware type: Ethernet, Address: 18:3d:a2:34:9e:b0
Collisions: 0
~> listdev
device Signal processing controller [11|80|0]
device 3b32: 5 Series/3400 Series Chipset Thermal Subsystem
device Serial bus controller (SMBus) [c|5|0]
device 3b30: 5 Series/3400 Series Chipset SMBus Controller
device Mass storage controller (SATA controller, AHCI 1.0) [1|6|1]
device 3b2f: 5 Series/3400 Series Chipset 6 port SATA AHCI Controller
device 3b07: QM57 Chipset LPC Interface Controller
device Bridge (PCI bridge, Subtractive decode) [6|4|1]
device 2448: 82801 Mobile PCI Bridge
device Serial bus controller (USB controller, EHCI) [c|3|20]
device 3b34: 5 Series/3400 Series Chipset USB2 Enhanced Host Controller
device 4239: Centrino Advanced-N 6200
device 3b4a: 5 Series/3400 Series Chipset PCI Express Root Port 5
device 3b48: 5 Series/3400 Series Chipset PCI Express Root Port 4
device 3b42: 5 Series/3400 Series Chipset PCI Express Root Port 1
device 3b56: 5 Series/3400 Series Chipset High Definition Audio
device 3b3c: 5 Series/3400 Series Chipset USB2 Enhanced Host Controller
device 10ea: 82577LM Gigabit Network Connection
device Communication controller [7|80|0]
device 3b64: 5 Series/3400 Series Chipset HECI Controller
device 0046: Core Processor Integrated Graphics Controller
device Bridge (Host bridge) [6|0|0]
device 0044: Core Processor DRAM Controller
If that was really caused by some package i’d appreciate if you could help me understand how and where to look for problems (i.e. check recently installed packages, see what they depend on or vice versa, etc) Or at least, where to read about it.
