Please list some Webpositive friendly sites here. I am interested in solutions people have found for online note taking. Many sites I try don’t work, like Standard Note. Any standout, solid services?
Fastmail !
Fastmail !
Which version of WebPositive? Beta3 will have a massively improved WebKit support.
Beta3 is eagerly awaited.
The Beta 3 version will be out in a matter of a few weeks if all goes according to schedule. Are you running Haiku nightly or Beta 2? You will benefit from the new version either way.
To see the actual version number you should scroll down.
Considering the copyright date it must be some sort of nightly build.
The copyright date of webpositive says nothing about the version of haikuwebkit being used.
