WebKit weekly report #2 | Haiku Project
It’s Friday again !
So, in my last blog post I told you I was converting our WebKit build files to CMake. This week I managed to get a working HaikuLauncher (the test browser that comes in the WebKit tree) and surf the web a bit with it. Getting an executable generated wasn’t too hard, but then I noticed that it wouldn’t run. Investigation showed that CMake had linked some gcc2 libraries with the gcc4-built WebKit, and, as you know, this can’t work. The main issue had already be fixed with the package manager branch. In Package Managed Haiku, the libs nad headers for each architecture are better separated, and CMake is aware of the 2 compiler versions. So, I upgraded my computer to run the Package Managed Haiku.
This is a companion discussion topic for the original entry at https://www.haiku-os.org/blog/pulkomandy/2013-10-04_webkit_weekly_report_2/
