Do not bet on this, because it is ported. The BeIDE sources also leaked and some (russian folks) patched it.
BeIDE binary runs as-is without porting with minor issues.
Thats true too.
The BeIDE sources mentions 3 copyright holder:
- Metrowerk
- Be
- a guy
I contacted NXP (they own the Metrowerks IP) and asked for relicensing their stuff, also contacted the guy, but i got no answer from them.
End of story.
Interesting. BeIDE is a lot nicer to use than the alternatives on Haiku. I thought there were issues with the way the dev tools are now packaged though? BeIDE expected them in specific locations and the gcc plugin was problematic. Does it work on 64bit also?
If you recompile it, then sure.
Maybe PowerPC compiler can be opened?
I spoke to someone at Metrowerks a long time ago (I forget his name, but he was the developer advocate and he was quite infamous int he Metrowerks community.) He told me he would look in to it. I never heard much back.
AFAIK, Be Inc had the IDE source, but the compiler was binary only and came from Metrowerks. The same compiler was used to compile PEF on all platforms (Classic MacOS, MacOS X, Windows and BeOS), so there are later versions of it kicking around. I guess any of the versions being opensourced would be handy.
I tried to find out who owns the Metrowerks IP, but it is unclear.
Afair MW was bought by Freescale, and its compiler business was bought by NXP. But i can be wrong.
They have absolutely no email address on their webpage (because fck do not disturb us mortal human), so i had to make extra miles.
You can try to contact them, maybe you will have more luck.
Re:Double Mangle condition
Looking at the source, wasm2c has a mechanism to prevent the double mangle so I may be able to simplify the test script.
UPDATE:
The source code to Haiku is full of preprocessor magic. Of course this defines the architecture long before the bytecode can be generated so every instance of
#ifdef __IM_A_PREPROCESSOR_FLAG
do this;
#endif
needs to be replaced with
if (__IM_A_BOOLEAN_CONST) {
do this;
so that
#define __IM_A_PREPROCESSOR_FLAG 1
can be repaced with
extern const bool __IM_A_BOOLEAN_CONST;
thus allowing the value of __IM_A_BOOLEAN_CONST to be linked in on the destination machine and the if statement to be constant folded by the link-time optimization pass.
Itāll be monotonous work but more importantly, will touch almost every part of the source code of the operating system. Expensive as a time sink even though the work is easy. Iām guessing that this may not make it to Beta 4, to say the least. Even worse, the GCC2 ABI requirement wonāt be met without an alternative compiler that supports link-time optimization.
I will welcome any critique of the situation but the amount of work that will be needed to merge all the packages into one bytecode may have to wait until the āglass elevatorā arrives on the first floor. (Meaning that it may have to wait until after release 1.)
Edit: If everybody was willing to pitch in and replace all the preprocessor macros in the config directory with constants, we collectively could make it beta 4!
CodeWarrior (the MacOS equivalent to BeIDE) is now owned by NXP but the current versions seem to be based on the Eclipse IDE and the GCC compiler: CodeWarriorĀ® Embedded Software Development Tools | NXP Semiconductors
I donāt know if they still have backup of the older versionsā¦
We can send them the x86 one.
On to plan B. Iām going to try to update the ApplicationKit headers so they donāt need to include the config.h macros as preprocessor definitions. Once I see what breaks Iāll report back.
Update
The extent of what I can accomplish for architecture neutrality using static compilation is limited by address bit width and endianness. This means 68k and Sparc32 can share a bytecode, as can PPC32 and ARMEB, but not x86 because it is little-endian. Little-endian 32-bit processors like ARM and x86 will be able to share a different bytecode. Futhermore, AMD64 and RISC-V64 will be able to share a bytecode because they are both little-endian and 64-bit. Finally, the fourth bytecode will be big-endian 64-bit.
Running a smaller address width or endian-swapped architecture (or both) will only be possible using a JIT. The speed penalty can be minimized by using a fast JIT like Cranelift but it will still have a speed penalty due to the compilations being concurrent or at load-time using AOT compilation.
Future Opportunities
I intend to fork bytecodes from the WebAssembly standard to support features that it presently does not support. 64-bit WebAssembly is going to be supported soon by the W3C so no need to fork for that. Two other features not supported or planned to be are big-endian platform support and macro injection.
Big-endian support will only require adding multi-byte loads and stores. I would not recommend using the same bytecode values for a big-endian load and store in case bi-endianness is supported as PPC and AArch64 both do endian swapping with a fair degree of transparency.
The final nail in fixed architecture is code injection. Normally associated with JIT compilation, code injection allows library code to contain macros in such a way that code from a performance limited libraries such as graphics drivers can actually put driver code in the executable of the application. This removes calling overhead from what might be implemented as a subroutine on one architecture, but a few opcodes on another. While often performed in JIT and AOT compilation strategies, it can also be implemented in static code by invoking a dependency check at startup.
More to comeā¦
More Updating
Iāve gotten Clang to compile my graphical āHello worldā class executable from Clang after having modelled it after the beginning example from the beginnersā tutorial. The command lines to build are much different. The significance of this is that GCC doesnāt have a WebAssembly backend to generate bytecode with.
The GCC build line is as follows:
g++ App.cpp -Os -lbe
The Clang 12 build line is this:
clang++ App.cpp -I/boot/system/develop/sources/haiku/headers/build/gcc-2.95.3 -fPIC -Os -lbe
The extra included directory contains the headers to the LibStdC++ runtimes. Apparently activating Position Independent Code is not optional either but must be specified. The resultant code is a couple hundred bytes smaller with Clang 12 than with GCC8, but thatās not a fair comparison considering that Clang 12 is on par with GCC 10 or 11 as far as generations go.
Hereās the C++ source listing of the program:
#include "App.h"
#include <StringView.h>
#include <Window.h>
App::App(void)
: BApplication("application/x-vnd.dw-TestApp")
BRect frame(100,100,500,400);
BWindow *myWindow = new BWindow(frame, "My First App", B_TITLED_WINDOW,
B_QUIT_ON_WINDOW_CLOSE);
frame.Set(10,10,11,11);
BStringView *label = new BStringView(frame, "myLabel", "Haiku Rocks!");
label->ResizeToPreferred();
myWindow->AddChild(label);
myWindow->Show();
int
main(void)
App *app = new App();
app->Run();
delete app;
return 0;
The App.h file is this:
#define APP_H
#include <Application.h>
class App : public BApplication
public:
App(void);
#endif
Now to get Clang to generate bytecode like Iāve already done on Linux.
Stay tunedā¦
But then
Now which ABI is targeted here? GCC2 or GCC4? If GCC4 then why the GCC2 include folder? If GCC2 then why ācouple hundred bytes smaller with Clang 12 than with GCC8ā ?
And if GCC2, let me ask: wouldnāt it easier to support only one ABI? One donāt really need to compile the whole os into webassembly, and most of the user-programs can be built with GCC4 ABI, then why to mess with the GCC2 ABI at all?
(Maybe I overlooked something here.)
And that include path doesnāt look to be shipped in default to me.
Tell me where the ABI v4 headers are to direct toward. Iāll try it. When I did a search for ānew.hā that was the only one that showed up.
GCC2 is not compatible with Clang. GCC 4+ headers should be used.
-I/boot/system/develop/tools/x86/lib/gcc/i586-pc-haiku/8.3.0/include/c++ -I/boot/system/develop/tools/x86/lib/gcc/i586-pc-haiku/8.3.0/include/c++/i586-pc-haiku
/x86 need to be removed for 64 bit system.
I agree. Where is the ABI v4 header for new.h? This was just the first attempt to make a graphical application work on Clang 12.
Edit: Thanks for the correct path.
