Has anybody installed a VM on Haiku? With Linux emulated in it? Ideally Qemu!
(Doesn’t need to be fast.)
Qemu works on Haiku indeed
Qemu works and is in the repos. We even have the aqemu front-end. Here is me running 32-bit Haiku in qemu under a 64-bit Haiku host.
That is probably going to be what gets me to install qemu. ![]()
On Linux I’m a big fan of AQemu. I often try obscure indie OS with it. Didn’t expect it to be ported to Haiku. ![]()
I still have to get used to the Haiku way, like for example
You can also use pkgman on the commandline, if that’s more convenient for you.
You have it as a real command too: query.
