VISION register, verify, identify problem
Hello everybody,
I have problems to identify to VISION.
Is there a problem with the Nickname-Server known?
I have read the: /msg nickserv help, and then
I registered, I verified and now i struggle to IDENTIFY
How to do that?
isn’t it: /msg IDENTIFY “password” NICKNAME
Edit:
Since yesterday, I did not get an answer on our Telegram channel on this matter! What happened to our community there?
Do not let the HAIKU COMMUNITY Split apart!
/msg NickServ help should give you the help text.
If you are already set to the nickname you registered then all you need to do after connecting to the IRC server is use the command /msg NickServ IDENTIFY <your password>.
Short version: /ns id <password> :slight_smile:
Some Info about VISION:
