Promet
October 3, 2018, 4:06am
1
From the Haiku website I am instructed that VirtualBox Guest Additions can be installed through HaikuDepot, however, I can’t find it in my own Haiku system.
I am aware that repositories have to be refreshed before searching for packages, but it is still no avail to find the package.
So do I miss something or the instruction in Haiku website is outdated?
You are using 64 bit Haiku, right?
SUMMARY="VirtualBox kernel modules and user-space tools for Haiku guests"
DESCRIPTION="VirtualBox is a free x86 virtualization solution allowing a wide \
range of x86 operating systems such as Windows, DOS, BSD or Linux to run on a \
Linux system.
This package contains the VirtualBox kernel modules and user-space \
tools for Haiku guests."
HOMEPAGE="https://www.virtualbox.org/"
#TODO:check user manual for full list
COPYRIGHT="2003-2014 Oracle Corporation."
LICENSE="GNU GPL v2
CDDL v1"
REVISION="2"
SOURCE_URI="http://download.virtualbox.org/virtualbox/$portVersion/VirtualBox-$portVersion.tar.bz2"
SOURCE_DIR="VirtualBox-$portVersion"
CHECKSUM_SHA256="db84ddf47d1ecd316ec46417595f0252e3ec2f67e35e1e17320aba87b7c2934f"
PATCHES="virtualbox_guest_additions-$portVersion.patchset"
ARCHITECTURES="x86_gcc2"
This file has been truncated. show original
What miqlas tried to say so ineloquently: The VB guest add on is currently only available for 32bit Haiku.
cb88
October 4, 2018, 2:54am
5
No the 32bit version of Haiku is just stuck on that old version, 64bit has the newer version.
ARCHITECTURES="!x86_gcc2 ?x86 ?x86_64"
? means untested. Test it, report back, and somebody will enable it.
