A bit late, but finally I managed to process my recordings of the talks at BeGeistert 026 “Marathon”. The quality isn’t terrific, looks like the picture was much better last time at BG 024, when we apparently didn’t darken the room so much. Audio might be slightly better, as I have used compression and a bit of filtering following advice from Haikollegue Sean Collins. I used Avidemux under Linux for de/muxing the audio track and encoding the final AVIs, and Audacity for processing the audio. The extensive video editing (j/k) was done with Clockwerk and WonderBrush under Haiku, which isn’t at all bad, just very unpolished…
This is a companion discussion topic for the original entry at https://www.haiku-os.org/blog/humdinger/2012-12-06_videos_begeistert_026_are/
