Hi!
I want to know if I can use “curl/curl.h” header to program under Haiku
Thanks
Hi!
Thanks
Haiku does have curl.
Simply make sure the curl development package is installed:
~> pkgman search curl
Status Name Description
S ca_root_certificates Bundle of CA root certificates
S curl A commandline-tool and library for downloading data from URLs
S curl_devel A commandline-tool and library for downloading data from URLs (development files)
curl_source A commandline-tool and library for downloading data from URLs (source files)
If it isn’t installed, pkgman install curl_devel
should solve that.
