haiku-master-hrev54026-x86_64-anyboot
Welcome to the Haiku shell.
~> listusb
13fe:3d00 /dev/bus/usb/0/0 “Kingston Technology Company Inc.” “USB DISK 2.0” ver. 0100
04ca:0095 /dev/bus/usb/0/8 “Lite-On Technology Corp.” “USB Gaming Keyboard” ver. 0153
03f0:1c41 /dev/bus/usb/0/9 “HP, Inc” “HP Gaming Mouse” ver. 0042
0000:0000 /dev/bus/usb/0/hub “HAIKU Inc.” “XHCI RootHub” ver. 0300
2109:3431 /dev/bus/usb/1/0/hub “VIA Labs, Inc.” “Hub” ver. 0420
0000:0000 /dev/bus/usb/1/hub “HAIKU Inc.” “XHCI RootHub” ver. 0300
8087:8008 /dev/bus/usb/2/0/hub “Intel Corp.” “” ver. 0005
0000:0000 /dev/bus/usb/2/hub “HAIKU Inc.” “EHCI RootHub” ver. 0200
8087:8000 /dev/bus/usb/3/0/hub “Intel Corp.” “” ver. 0005
0000:0000 /dev/bus/usb/3/hub “HAIKU Inc.” “EHCI RootHub” ver. 0200
~> listdev
device Serial bus controller (SMBus) [c|5|0]
device 8c22: 8 Series/C220 Series Chipset Family SMBus Controller
device Mass storage controller (SATA controller, AHCI 1.0) [1|6|1]
device 8c02: 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode]
device 8c5c: H81 Express LPC Controller
device Serial bus controller (USB controller, EHCI) [c|3|20]
device 8c26: 8 Series/C220 Series Chipset Family USB EHCI #1
device Serial bus controller (USB controller, XHCI) [c|3|30]
vendor 1106: VIA Technologies, Inc.
device 3483: VL805 USB 3.0 Host Controller
device 8c16: 8 Series/C220 Series Chipset Family PCI Express Root Port #4
vendor 10ec: Realtek Semiconductor Co., Ltd.
device 8168: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
device 8c14: 8 Series/C220 Series Chipset Family PCI Express Root Port #3
device 8c10: 8 Series/C220 Series Chipset Family PCI Express Root Port #1
device 8c20: 8 Series/C220 Series Chipset High Definition Audio Controller
device 8c2d: 8 Series/C220 Series Chipset Family USB EHCI #2
device Communication controller [7|80|0]
device 8c3a: 8 Series/C220 Series Chipset Family MEI Controller #1
device 8c31: 8 Series/C220 Series Chipset Family USB xHCI
vendor 10de: NVIDIA Corporation
device 0e0b: GK106 HDMI Audio Controller
device 11c0: GK106 [GeForce GTX 660]
device 0c01: Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller
device Bridge (Host bridge) [6|0|0]
device 0c00: 4th Gen Core Processor DRAM Controller
~> ~> listusb
bash: /boot/home: Is a directory
~> 13fe:3d00 /dev/bus/usb/0/0 “Kingston Technology Company Inc.” “USB DISK 2.0” ver. 0100
bash: 13fe:3d00: command not found
~> 04ca:0095 /dev/bus/usb/0/8 “Lite-On Technology Corp.” “USB Gaming Keyboard” ver. 0153
bash: 04ca:0095: command not found
~> 03f0:1c41 /dev/bus/usb/0/9 “HP, Inc” “HP Gaming Mouse” ver. 0042
bash: 03f0:1c41: command not found
~> 0000:0000 /dev/bus/usb/0/hub “HAIKU Inc.” “XHCI RootHub” ver. 0300
bash: 0000:0000: command not found
~> 2109:3431 /dev/bus/usb/1/0/hub “VIA Labs, Inc.” “Hub” ver. 0420
bash: 2109:3431: command not found
~> 0000:0000 /dev/bus/usb/1/hub “HAIKU Inc.” “XHCI RootHub” ver. 0300
~> 8087:8008 /dev/bus/usb/2/0/hub “Intel Corp.” “” ver. 0005
bash: 8087:8008: command not found
~> 0000:0000 /dev/bus/usb/2/hub “HAIKU Inc.” “EHCI RootHub” ver. 0200
~> 8087:8000 /dev/bus/usb/3/0/hub “Intel Corp.” “” ver. 0005
bash: 8087:8000: command not found
~> 0000:0000 /dev/bus/usb/3/hub “HAIKU Inc.” “EHCI RootHub” ver. 0200
~> ~> listdev
~> device Serial bus controller (SMBus) [c|5|0]
bash: syntax error near unexpected token (' ~> vendor 8086: Intel Corporation bash: vendor: command not found ~> device 8c22: 8 Series/C220 Series Chipset Family SMBus Controller bash: device: command not found ~> ~> device Mass storage controller (SATA controller, AHCI 1.0) [1|6|1] bash: syntax error near unexpected token
~> device 8c02: 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode]
~> device Bridge (ISA bridge) [6|1|0]
bash: syntax error near unexpected token (' ~> vendor 8086: Intel Corporation bash: vendor: command not found ~> device 8c5c: H81 Express LPC Controller bash: device: command not found ~> ~> device Serial bus controller (USB controller, EHCI) [c|3|20] bash: syntax error near unexpected token
~> device 8c26: 8 Series/C220 Series Chipset Family USB EHCI #1
~> device Serial bus controller (USB controller, XHCI) [c|3|30]
bash: syntax error near unexpected token (' ~> vendor 1106: VIA Technologies, Inc. bash: vendor: command not found ~> device 3483: VL805 USB 3.0 Host Controller bash: device: command not found ~> ~> device Bridge (PCI bridge, Normal decode) [6|4|0] bash: syntax error near unexpected token
~> device 8c16: 8 Series/C220 Series Chipset Family PCI Express Root Port #4
~> device Network controller (Ethernet controller) [2|0|0]
bash: syntax error near unexpected token (' ~> vendor 10ec: Realtek Semiconductor Co., Ltd. bash: vendor: command not found ~> device 8168: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller bash: device: command not found ~> ~> device Bridge (PCI bridge, Normal decode) [6|4|0] bash: syntax error near unexpected token
~> device 8c14: 8 Series/C220 Series Chipset Family PCI Express Root Port #3
bash: syntax error near unexpected token (' ~> vendor 8086: Intel Corporation bash: vendor: command not found ~> device 8c10: 8 Series/C220 Series Chipset Family PCI Express Root Port #1 bash: device: command not found ~> ~> device Multimedia controller (Audio device) [4|3|0] bash: syntax error near unexpected token
~> device 8c20: 8 Series/C220 Series Chipset High Definition Audio Controller
bash: syntax error near unexpected token (' ~> vendor 8086: Intel Corporation bash: vendor: command not found ~> device 8c2d: 8 Series/C220 Series Chipset Family USB EHCI #2 bash: device: command not found ~> ~> device Communication controller [7|80|0] bash: device: command not found bash: 80: command not found bash: 0]: command not found ~> vendor 8086: Intel Corporation bash: vendor: command not found ~> device 8c3a: 8 Series/C220 Series Chipset Family MEI Controller #1 bash: device: command not found ~> ~> device Serial bus controller (USB controller, XHCI) [c|3|30] bash: syntax error near unexpected token
~> device 8c31: 8 Series/C220 Series Chipset Family USB xHCI
bash: syntax error near unexpected token (' ~> vendor 10de: NVIDIA Corporation bash: vendor: command not found ~> device 0e0b: GK106 HDMI Audio Controller bash: device: command not found ~> ~> device Display controller (VGA compatible controller, VGA controller) [3|0|0] bash: syntax error near unexpected token
~> device 11c0: GK106 [GeForce GTX 660]
bash: syntax error near unexpected token (' ~> vendor 8086: Intel Corporation bash: vendor: command not found ~> device 0c01: Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller bash: device: command not found ~> ~> device Bridge (Host bridge) [6|0|0] bash: syntax error near unexpected token
~> device 0c00: 4th Gen Core Processor DRAM Controller
