I’m booting on an old Dell Latitude. I used dd on Linux to copy the image (latest release) to the USB stick.
Where can I start trouble shooting?
Welcome
For bug reports you should add a report to Haiku (haiku-os.org)
But asking for support on a bug tracker is usually out of bounds.
the developers look more for reports on the bug tracker than in the forum
https://dev.haiku-os.org/ticket/17881
That aside, I’m still open to pointers on how to begin troubleshooting.
Have a look here.
Though I guess the culprit was identified and you should retry with a nightly hrev56377 or later when available.
System throwing a KDL at you is a bug, if it turns out to be bon-reproducable or a user error that is fine.
Thanks - exactly what I’m looking for. Latest nightly has same issue so I’ll start working through this.
