r1~beta3_hrev55181_52-1-x86_64.hpkg consistently fails to download at approximately 6%. Same for the 32bit package. The remaining 6 packages never get queued-up. Very frustrating!
i had the same thing happen ~ 48 hours ago… trying again half an hour later helped…
I am still consistently crashing on the update download at about the same place especially on the kernal update. On earlier beta versions waiting a bit would help but this is failing each and every time. Would the developers consider a torrent style option perhaps?
Torrents are available for downloading the ISOs, actually. You can then boot from and install these and all the data from your existing installation will be carried over:
