It says unable to create offscreen bitmap for webkit contents when I try to pull up WebPositive. How do I fix this to run WebPositive?
Please report bugs at the bugtracker. You will notice there that the bug is known, that a fix was created, and that the haikuwebkit 1.6.3 pachkage should be in the repositories “soon” (but there seems to be some problems with pqckqge builders so it takes a few days instead of a few hours).
Meanwhile, you can roll back to an older version of Haiku.
FYI, the haikuwebkit 1.6.3 package has now hit the eu.hpkg.haiku-os.org 32bit repo. It’s save to update WRT Web+.
