Trouble installing MidnightCommander in Haiku PM
Hello. I downloaded MidnighCommander with the haikuporter tool. I get the hpkg file, however when I copy to /home/config/packages I get the following error:
“nothing provides lib: libglib_2.0 >= 0.3800.1 needed by mc-4.8.11-1”
However, I had the glib2-2.38.1-1.hpkg already installed in my system, and I had the following libs:
/boot/home/config/lib
libglib-2.0.so.0
libglib-2.0.so.0.3800.1
Anyone had this issue?
Thank you!!!
The installed glib package might not declare what the mc package expects. You can check by running “package list -i ~/config/package/glib-…” in Terminal.
