Hello, I’m a user of haiku that found it when I was looking for something to run on outdated hardware , and basically works out of the box with no configuration, a child could use this OS, however it has stability problems with some ported software and when working with non-native file systems and devices, and hangs rather frequently, however it is stable enough for most tasks and I wondered whether a tor relay could run on it since I’m already operating one. I noticed tor was available in the package repo , installed it and it bootstrapped to the network but did not seem to begin acting as a relay, maybe it is because I did not have a torrc file prepared, or maybe this version is only acting as a client for browsing tor in webpositive. So is this not possible yet, or can tor be compiled for relay use on haiku, this would be good for OS diversity as more than 95% of tor relays are running on Linux distributions, which could be a single point of failure if a vulnerability is discovered in the Linux kernel, I think this OS is fast and good for this task, so is it feasible?
