Toki Pona translation: Request for committer rights
The network effect seems to be Big Techs most effective weapon.
No matter how much better any given alternative is,and how many good reasons there are for switching,the “…but all people are already there” argument always wins and kills off every chance for improvement :confused:
It’s somehow understandable if you don’t want to fight this battle,it’s hard to convince people who don’t have any arguments other than their own laziness (I mean the people in your community,not you) but then again the bridge option is a good idea.
Then people who don’t want to use Discord can take part and maybe the community will gradually migrate over to the better solution if others see that something better exists.
Forcing people into a closed platform without offering a bridge only contributes to making their network effect even worse.
The default user experience for IRC is just bad. You join a channel and you don’t see the history, so it looks like no one is talking (even if the last message was one minute before you joined). Nicknames have restrictions and don’t allow unicode (you have an accented or non-latin char in your name? toug luck, pick another one). If you disconnect you cannot catch up with messages you missed. Using it requires mastering a pseudo-command-line with /join, /nick and so on.
And that’s after you have figured out what an IRC network is, how to connect to a specific one, that you don’t need to read the mix of technical info and random things the server has put in its MOTD, and how to join the right channel.
If you want people to stop using walled gardens, you should understand why they do so, and in this case I think it’s pretty clear.
We have all seen how people jump from one big tech platform to another every few years. So that’s not true. The big tech platform will become bad eventually and people will move. Open source developers have been unable to develop a convincing clone that people land on, for both technical, design and marketing reasons. That’s where we should work if we want this to change.
Anyway, both you and nephele are, I assume, not going to take part in the Toki Pona translation, no matter where the discussion channel ends up being. So I think you should stop telling people what to do for a community that you will not join.
I will certainly not because of discord… (Though I am more bussy learning esperanto) I’m not sure where your problem is with my statements before. If the required expectation is for a potential translation member to have to interact with discord that seems wildly inapropriate to me. And I also wrote that it should be okay aslong as it is not required. Where do you see a problem with this?
Discord wont be a requirement for the translation, It will just be where I MIGHT handle discussions about terminology/translations, you can still contribute without it, I just want a platform where discussions can take place.
The discussions would be like, what would the tokiponization of “Haiku” be for a possible sitelen pona variant?
What fonts, tools, terms would be changed/kept?
Stuff like that.
I don’t want translations to require going through the Discord at all, or any chatting platform; It’d just make it easier to get more tokiponists involved.
Not wanting to contribute due to a optional thing just is a bit silly.
As I wrote, I would not if it were mandatory. :wink:
Speaking of tokiponization, I still need to know if the sitelen Lasina (latin-script) version can use tokiponized terms, such as:
ilo Awiku (Haiku, somewhat derived from the Wikipedia translation, though that one is a bit strange)
ilo linluwi PoMan (Poorman)
ilo sitelen Pi (Pe)
etc…
It’d make later sitelen pona conversion easier.
I’m unsure if that kind of stuff with Latin-based script languages is permitted, hints the question here.
Though in the same boat, later automatic word-swaps for a then automated sitelen pona conversion could be done as well, though with how toki pona works, it’d be easier to program such a thing with pre-tokiponized strings.
I see a problem with a dozen of messages arguing about this (indeed, mostly from nipos). I think we can stop there, it’s pretty clear we don’t like Discord and why, but ultimately it’s up to the language manager to make a decision depending on what the translator team is happy with. Carrying on the discussion about this is not making people feel welcome here, and I think we should be more welcoming, even if people choose the “wrong” tools for some reason.
DigiSpaceProductions has all the information they need to make their own decision now.
Generally texts should have the application name in a placeholder, so that the “Translate application and folder names” setting in Locale preferences allows users to choose if they want this or not.
Well I dont know how it works fully, also toki pona would make it hard to do that, at least assuming Haiku ever gets sitelen pona, USCUR or not.
Also ive seen some users see proper latin names in translations (like, jan Hercules, for instance) and question on if its AI, as AI tends to not tokiponize names; and I would want to avoid people assuming AI was involved in translation at all, though thats a minority.
I don’t know about the Toki Pona translation, but for some other languages this indeed happened, people just copy-pasting from an online translation tool. I would recommend against it, but as the language manager it’s up to you to set the rules (or not set any rules).
Some language managers prefer to work outside Pootle first and then update the translations after they have been validated by the translation team. Some just work alone. Some have strict rules for the vocabulary and others don’t.
I just need to know if latin script transliteration is allowed really; so discussion can be done later on for tokiponizing terms properly, so it all conforms to the language’s rules; else we have a Minecraft translation situation.
We don’t forbid it if that is what you are asking? If it makes sense for Toki Pona feel free to do so.
The only “option” we have regarding app names for users is wether they should be localized or not. i.e if it is not localized you might have an easier time asking for help on a forum, but you may have more problems if you don’t speak english.
I don’t think this option directly mandates any alphabet or anything.
The untranslated name will always be in latin script and in english.
For the translated name you do what makes sense in Toki Pona, and I would have no idea. Then everyone can decide if they want to keep the english name or a translated one, since this is a more personal choice (some people really don’t want any english texts; in some cultures it makes more sense than in others; some languages don’t have very good translations for the application names; some of the names have english wordplays that don’t translate well to other languages, etc)
