then it should be possible to use a unix pipe (mkfifo) to read audio with any media player available
Maybe we should disable the build at haikuports as there is no audio backend to this?
I think so. No need for bad user experience.
You probably have the source code of this application, so you could do a grep for the “Permission missing” string to see where it gets emmitted to see what triggers it. If you are lucky, it is emitted in a local source code somewhere, but if you are unlucky, then it could come from the Spotify API over the network. Who knows. Good luck to dive in.
