Three requests for help
hello friends, I have three problems I would like help with. first duct in my old acer aspire one (yes, I’m trying to revive the poor guy) is not reproducing audio in any way from what I saw the controller is a Azalia (Intel HDA)
The second problem is how to disable the internal keyboard of the notebook via command? and last but not least, what’s the most important to me is how to make my graphical desk recognize the touch? I can even get the canets to move the mouse pointer but the click does not work running a command suggested by a brave guy here forum gave this exit: waltop international media tablet corp. "media tablet 16.6 ver, 0107. if you really appreciate it if you can get it to work on my good old haikai.
ps: I can not change the topic of the post I’m typing direct from the positive web and for some reason does not let me choose the category. I apologize to the moderator
A placa de som Azalia dev funcionar… porem seria bom se você pudesse baixar aqui or copiar o seu log de demsg /var/log/dmsg. Para que podemos ver mais facil o que esta dando o problema.
Nao sei como desabilitar o teclado pelo linha de comando, por que esta querendo fazer assim mesmo?
Haiku realmente não tem suporte para tableta ou caneta assim so faz emulação de mouse.
BTW Caneta = pen (even for tablets)
English summary: The Azalia card should work, so it would be good if you could upload here or copy your dmesg log. So we can see more easily what is giving you the problem.
I don’t know how to disable the keyboard from the CLI but why do you want to do this really?
Haiku doesn’t really have tablet support only emulation of mouse on tablet screens.
Thanks for the quick response. I need to disable the internal declare of the notebook because it is defective and disrupts the use of the equipment. I use a conventional usb keyboard. As for the file that requested me dmsg simply does not exist on my machine. and at last there was no way to “trick” the machine and make the click of the pen recognize as it might move the pointer? Finally, are you Brazilian?
Brasileiro não, mas morei em MG uns 5 anos, antes da faculdade… Meus pais são missionários batistas la em MG at hoje.
Se o teclado (keyboard) ha defeito talvez pode desconeta-lo phisicamente nomalmente nao e muito difficil por que teclado de laptop e connectado solomented pelo um cabo tipo fita… talvez o defeito e por que esta solto um poco ai dentro?
Falei errado sobre dmesg… e /var/log/syslog mas ele faz a mesma coisa quanto a /var/log/dmesg no Linux.
English:
I’m not Brazlian but lived in MG for 5 years, and my parents are still Baptist missionaries there even now.
If the keyboard is defective maybe you can disconnect it phsyically… usually that isn’t too hard as it is just a ribbon connector, Actually perhaps it is just loose in side causing the problem?
I misspoke about dmesg, I should have said /var/log/syslog
The keyboard is probably attached via PS/2, so blacklisting the PS/2 keyboard driver should suffice there.
did not find in the bootloader menu of haiku any option to add blacklist ps / 2 or any other peripheral. As for colleague cb88 below, follow the information you requested:
KERN: dos_std_ops()
KERN: trying: file_systems/fat/v1
KERN: returned: -1
KERN: dos_std_ops()
KERN: trying: file_systems/bfs/v1
KERN: returned: -1
KERN: scanning with: partitioning_systems/intel/map/v1
KERN: intel: pm_scan_partition(0, 1: 0, 320072933376, 512)
KERN: KDiskDeviceManager::_ScanPartition(/dev/disk/usb/0/0/0)
KERN: trying: partitioning_systems/intel/extended/v1
KERN: intel: ep_identify_partition(0, 6291456, 629145600, 512)
KERN: returned: -1
KERN: trying: partitioning_systems/session/v1
KERN: returned: -1
KERN: trying: partitioning_systems/efi_gpt/v1
KERN: returned: -1
KERN: trying: partitioning_systems/intel/map/v1
KERN: intel: pm_identify_partition(0, 7: 6291456, 629145600, 512)
KERN: returned: -1
KERN: trying: file_systems/btrfs/v1
KERN: e[34mbtrfs:e[0m invalid superblock!
KERN: returned: -1
KERN: trying: file_systems/devfs/v1
KERN: returned: -1
KERN: trying: file_systems/exfat/v1
KERN: e[34mexfat:e[0m invalid superblock!
KERN: returned: -1
KERN: trying: file_systems/attribute_overlay/v1
KERN: returned: -1
KERN: trying: file_systems/rootfs/v1
KERN: returned: -1
KERN: trying: file_systems/bindfs/v1
KERN: returned: -1
KERN: trying: file_systems/packagefs/v1
KERN: returned: -1
KERN: trying: file_systems/ntfs/v1
KERN: fs_identify_partition: boot signature NTFS doesn’t match
KERN: returned: -1
KERN: trying: file_systems/ext2/v1
KERN: e[34mext2:e[0m invalid superblock!
KERN: returned: -1
KERN: trying: file_systems/iso9660/v1
KERN: identify(0, 0xffffffff82469900)
KERN: returned: -1
KERN: trying: file_systems/nfs4/v1
KERN: returned: -1
KERN: trying: file_systems/cdda/v1
KERN: usb_disk: unhandled ioctl 10102
KERN: returned: -1
KERN: trying: file_systems/log_overlay/v1
KERN: returned: -1
KERN: trying: file_systems/write_overlay/v1
KERN: returned: -1
KERN: trying: file_systems/reiserfs/v1
KERN: returned: -1
KERN: trying: file_systems/nfs/v1
KERN: returned: -1
KERN: trying: file_systems/udf/v1
KERN: read_pos(pos:3221233664, len:512) failed with: 0xffffffffffffffff
KERN: udf_recognize: Invalid sequence. status = -1
KERN: returned: -1
KERN: dos_std_ops()
KERN: returned: -1
KERN: dos_std_ops()
KERN: returned: 0.8
KERN: scanning with: file_systems/bfs/v1
KERN: KDiskDeviceManager::_ScanPartition(/dev/disk/usb/0/0/1)
KERN: intel: ep_identify_partition(0, 635437056, 2949120, 512)
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: intel: pm_identify_partition(0, 8: 635437056, 2949120, 512)
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: read_pos(pos:325343780864, len:512) failed with: 0xffffffffffffffff
KERN: returned: -1
KERN: dos_std_ops()
KERN: returned: 0.8
KERN: returned: -1
KERN: scanning with: file_systems/fat/v1
KERN: KDiskDeviceManager::_ScanPartition(/dev/disk/usb/0/0/2)
KERN: intel: ep_identify_partition(0, 638386176, 319433998336, 512)
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: intel: pm_identify_partition(0, 9: 638386176, 319433998336, 512)
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: usb_diKERN: sk: unhandled ioctl 10102
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: returned: -1
KERN: read_pos(pos:326853730304, len:512) failed with: 0xffffffffffffffff
KERN: returned: -1
KERN: returned: -1
KERN: returned: 0.8
KERN: device 0: /dev/disk/scsi/0/0/0/raw
KERN: media status: No error
KERN: device flags: 2
KERN: offset: 0
KERN: size: 500107862016 (476940.23 MB)
KERN: content size: 500107862016
KERN: block size: 512
KERN: child count: 3
KERN: index: -1
KERN: status: 0
KERN: flags: 5
KERN: volume: -1
KERN: disk system: partitioning_systems/intel/map/v1
KERN: name: WDC WD5000BPVT-22HXZ
KERN: content name:
KERN: type:
KERN: content type: Intel Partition Map
KERN: params:
KERN: content params:
KERN: partition 3: /dev/disk/scsi/0/0/0/0
KERN: offset: 1048576
KERN: size: 6442450944 (6144 MB)
KERN: content size: 0
KERN: child count: 0
KERN: index: 0
KERN: status: 2
KERN: flags: 0
KERN: volume: -1
KERN: disk system:
KERN: name:
KERN: content name:
KERN: type: Linux swap
KERN: content type:
KERN: params: type = 130 ; active = 0
KERN: partition 4: /dev/disk/scsi/0/0/0/1
KERN: offset: 6443499520
KERN: size: 296197000192 (282475.471 MB)
KERN: index: 1
KERN: status: 2
KERN: flags: 0
KERN: volume: -1
KERN: disk system:
KERN: name:
KERN: content name:
KERN: type: Linux native
KERN: content type:
KERN: params: type = 131 ; active = 1
KERN: partition 5: /dev/disk/scsi/0/0/0/2
KERN: offset: 302642101248
KERN: size: 197464687616 (188317 MB)
KERN: content size: 197464687616
KERN: child count: 1
KERN: index: 2
KERN: status: 0
KERN: flags: 4
KERN: volume: -1
KERN: disk system: partitioning_systems/intel/extended/v1
KERN: name:
KERN: content name:
KERN: type: Intel Extended Partition
KERN: content type: Intel Extended Partition
KERN: params: type = 15 ; active = 0
KERN: partition 6: /dev/disk/scsi/0/0/0/2_0
KERN: offset: 302642102272
KERN: size: 197464686592 (188317 MB)
KERN: content size: 197464686592
KERN: block size: 4096
KERN: index: 0
KERN: status: 0
KERN: flags: 2
KERN: volume: -1
KERN: disk system: file_systems/ext2/v1
KERN: name:
KERN: content name: arquivos
KERN: content type: Ext2 File System
KERN: params: active false ;
KERN: partition_table_offset 302642101248 ;
KERN:
KERN: device 1: /dev/disk/usb/0/0/raw
KERN: offset: 0
KERN: size: 320072933376 (305245.335 MB)
KERN: content size: 320072933376
KERN: index: -1
KERN: status: 0
KERN: flags: 5
KERN: volume: -1
KERN: name: SAMSUNG HM321HI 2AJ1
KERN: content name:
KERN: type:
KERN: params:
KERN: partition 7: /dev/disk/usb/0/0/0
KERN: offset: 6291456
KERN: size: 629145600 (600 MB)
KERN: content size: 629145600
KERN: block size: 2048
KERN: index: 0
KERN: status: 0
KERN: flags: 2
KERN: volume: -1
KERN: disk system: file_systems/bfs/v1
KERN: name:
KERN: content name: Haiku
KERN: type: Be File System
KERN: content type: Be File System
KERN: params: type = 235 ; active = 1
KERN: partition 8: /dev/disk/usb/0/0/1
KERN: offset: 635437056
KERN: size: 2949120 (2.812 MB)
KERN: content size: 2949120
KERN: index: 1
KERN: status: 0
KERN: flags: 2
KERN: volume: -1
KERN: disk system: file_systems/fat/v1
KERN: name:
KERN: content name: no name
KERN: type: EFI
KERN: content type: FAT32 File System
KERN: params: type = 239 ; active = 0
KERN: partition 9: /dev/disk/usb/0/0/2
KERN: offset: 638386176
KERN: size: 319433998336 (304636 MB)
KERN: content size: 319433998336
KERN: index: 2
KERN: status: 0
KERN: flags: 2
KERN: volume: -1
KERN: name:
KERN: content name: julio
KERN: params: type = 235 ; active = 0
KERN: device 2: /dev/disk/usb/1/0/raw
KERN: media status: No media present
KERN: device flags: 5
KERN: HDA: Detected controller @ PCI:0:1:1, IRQ:19, type 1002/1314 (1025/0598)
KERN: pci_reserve_device(0, 20, 2, hda)
KERN: ps2: keyboard found
KERN: HDA: Detected controller @ PCI:0:20:2, IRQ:16, type 1002/4383 (1025/0598)
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/audio/hmulti/hda
KERN: sis7018:init_hardware:ver:2.0.2
KERN: /dev/net/atheroswifi/0: media change, media 0x300a0 quality 1000 speed 1000000000
KERN: echo3g: init_hardware()
KERN: echo3g: no card found
KERN: auich: init_hardware()
KERN: emuxki: init_hardware()
KERN: Highpoint-IDE: supports_device()
Last message repeated 1 time
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/bus/usb_raw
KERN: set MTRRs to:
KERN: mtrr: 0: base: 0xdfe00000, size: 0x200000, type: 0
KERN: mtrr: 1: base: 0xf0000000, size: 0x10000000, type: 0
KERN: mtrr: 2: base: 0xe0000000, size: 0x20000000, type: 1
KERN: allocate_io_interrupt_vectors: allocated 1 vectors starting from 25
KERN: msi_allocate_vectors: allocated 1 vectors starting from 25
KERN: msi enabled: 0x0081
KERN: hda: using MSI vector 25
KERN: hda: DMA snooping: no
KERN: hda: HDA v1.0, O:1/I:0/B:0, #SDO:1, 64bit:yes
KERN: set MTRRs to:
KERN: mtrr: 0: base: 0x1b624000, size: 0x1000, type: 0
KERN: mtrr: 1: base: 0xdfe00000, size: 0x200000, type: 0
KERN: mtrr: 2: base: 0xf0000000, size: 0x10000000, type: 0
KERN: mtrr: 3: base: 0xe0000000, size: 0x20000000, type: 1
KERN: hda: Codec 0 Vendor: 1002 Product: aa01, Revision: 1.0.2.0 Quirks: 0700
KERN: hda: Audio Group: Output delay: 0 samples, Input delay: 0 samples, Beep Generator: no
KERN: hda: #GPIO: 0, #GPO: 0, #GPI: 0, unsol: no, wake: no
KERN: hda: Supported formats: 16bits
KERN: hda: Supported rates: 32khz 44khz 48khz
KERN: hda: widget start 2, count 2
KERN: hda: 2: Audio output
KERN: hda: Supported power states:
KERN: hda: [Digital] [Stereo]
KERN: hda: 3: Pin complex
KERN: hda: [Output]
KERN: hda: Jack, HDMI Digital other out, Other digital, N/A, Association:1
KERN: hda: [Digital] [Conn. list] [Unsol. responses] [Stereo]
KERN: hda: Inputs: <2>
KERN: hda: build output tree: use mixer
KERN: hda: look at pin widget 3 (1 inputs)
KERN: hda: try widget 2: 0xffffffff8fcd4918
KERN: hda: try without mixer!
KERN: hda: build output tree: don’t use mixer
KERN: hda: widget 2 is candidate
KERN: hda: output: added output widget 2
KERN: hda: add pin widget 3
KERN: hda: build input tree
KERN: hda: build input tree failed
KERN: hda: build tree!
KERN: hda: Audiogroup:
KERN: hda: [Pres Detect][Output]
KERN: hda: Enabled unsolicited responses on widget 3
KERN: hda: ENABLE pin widget 3
KERN: hda: hda_audio_group_get_widgets failed for playback stream
KERN: hda: hda_audio_group_get_widgets failed for record stream
KERN: hda: streams playback 0x0000000000000000, record 0x0000000000000000
KERN: hda: Failed to setup new audio function group (No such device)!
KERN: hda: no active codec
KERN: set MTRRs to:
KERN: hda: ERROR: No such device(80007007)
KERN: set MTRRs to:
KERN: hda: DMA snooping: yes
KERN: hda: HDA v1.0, O:4/I:4/B:0, #SDO:1, 64bit:yes
KERN: hda: Codec 0 Vendor: 14f1 Product: 506c, Revision: 1.0.0.2 Quirks: 0700
KERN: hda: Audio Group: Output delay: 15 samples, Input delay: 15 samples, Beep Generator: yes
KERN: hda: #GPIO: 4, #GPO: 0, #GPI: 0, unsol: yes, wake: no
KERN: hda: Supported formats: 16bits 20bits 24bits
KERN: hda: Supported rates: 44khz 48khz 96khz
KERN: hda: widget start 16, count 22
KERN: hda: 16: Audio output
KERN: hda: Supported rates: 44khz 48khz 96khz 192khz
KERN: hda: Supported power states: D0 D1 D2 D3
KERN: hda: [L-R swap] [Power] [Format override] [Amplifier override] [Out amplifier] [Stereo]
KERN: hda: Out Amp: supports mute, step size: 1 dB, # steps: 74, offset to 0 dB: 74
KERN: hda: 17: Audio output
KERN: hda: 18: Audio output
KERN: hda: Supported formats: 16bits 20bits 24bits bitstream
KERN: hda: [Power] [Digital] [Format override] [Stereo]
KERN: hda: 19: Beep generator
KERN: hda: [Amplifier override] [Out amplifier]
KERN: hda: Out Amp: step size: 4 dB, # steps: 7, offset to 0 dB: 7
KERN: hda: 20: Audio input
KERN: hda: [L-R swap] [Power] [Conn. list] [Format override] [Amplifier override] [In amplifier] [Stereo]
KERN: hda: In Amp: supports mute, step size: 1 dB, # steps: 80, offset to 0 dB: 74
KERN: hda: Inputs: 23 24 35 36
KERN: hda: 21: Audio input
KERN: hda: 22: Audio input
KERN: hda: 23: Audio selector
KERN: hda: [Power] [Conn. list] [Amplifier override] [Out amplifier] [Stereo]
KERN: hda: Out Amp: step size: 10 dB, # steps: 4, offset to 0 dB: 0
KERN: hda: Inputs: 26 27 29 30
KERN: hda: 24: Audio selector
KERN: hda: 25: Pin complex
KERN: hda: [Output]
KERN: hda: Jack, Left HP out, 1/8", Black, Association:4
KERN: hda: [Power] [Conn. list] [Unsol. responses] [Stereo]
KERN: hda: Inputs: 16 17
KERN: hda: 26: Pin complex
KERN: hda: [Input]
KERN: hda: Jack, Left Mic in, 1/8", Black, Association:3
KERN: hda: [Power] [Unsol. responses] [Stereo]
KERN: hda: 27: Pin complex
KERN: hda: [Input] [Output]
KERN: hda: Jack, Left Mic in, 1/8", Pink, Association:3
KERN: hda: 28: Pin complex
KERN: hda: [Output]
KERN: hda: None, Line out, N/A, N/A, Association:15
KERN: hda: 29: Pin complex
KERN: hda: 30: Pin complex
KERN: hda: [Input]
KERN: hda: Fixed, Mic in, Other analog, N/A, Association:2
KERN: hda: 31: Pin complex
KERN: hda: [Output]
KERN: hda: Fixed, Speaker, Other analog, N/A, Association:1
KERN: hda: [Power] [Conn. list] [Stereo]
KERN: hda: 32: Pin complex
KERN: hda: [Output]
KERN: hda: [Power] [Digital] [Conn. list] [Unsol. responses] [Stereo]
KERN: hda: Inputs: <18>
KERN: hda: 33: Audio output
KERN: hda: 34: Pin complex
KERN: hda: [Output]
KERN: hda: Inputs: <33>
KERN: hda: 35: Pin complex
KERN: hda: [Input]
KERN: hda: [Power] [Amplifier override] [In amplifier] [Stereo]
KERN: hda: In Amp: step size: 12 dB, # steps: 4, offset to 0 dB: 0
KERN: hda: 36: Audio mixer
KERN: hda: [Power] [Conn. list] [Amplifier override] [In amplifier] [Stereo]
KERN: hda: In Amp: supports mute, step size: 1 dB, # steps: 74, offset to 0 dB: 74
KERN: hda: 37: Vendor defined
KERN: hda: look at pin widget 25 (2 inputs)
KERN: hda: try widget 16: 0xffffffff8fd01000
KERN: hda: try widget 17: 0xffffffff8fd010ac
KERN: hda: look at pin widget 28 (2 inputs)
KERN: hda: look at pin widget 29 (2 inputs)
KERN: hda: look at pin widget 31 (2 inputs)
KERN: hda: look at pin widget 32 (1 inputs)
KERN: hda: try widget 18: 0xffffffff8fd01158
KERN: hda: look at pin widget 34 (1 inputs)
KERN: hda: try widget 33: 0xffffffff8fd01b6c
KERN: hda: widget 16 is candidate
KERN: hda: output: added output widget 16
KERN: hda: add pin widget 25
KERN: hda: Inputs: <23> 24 35 36
KERN: hda: Inputs: <26> 27 29 30
KERN: hda: [Pres Detect][HP Drive][Output]
KERN: hda: Inputs: <16> 17
KERN: hda: [Pres Detect][Input][VRef HIZ][VRef 50][VRef 80]
KERN: hda: [Pres Detect][Output][Input][VRef HIZ][VRef 50][VRef 80][EAPD]
KERN: hda: [Pres Detect][Output][Input][EAPD]
KERN: hda: [Output]
KERN: hda: [Output]
KERN: hda: [Output]
KERN: hda: [Input]
KERN: hda: Enabled unsolicited responses on widget 25
KERN: hda: Enabled unsolicited responses on widget 26
KERN: hda: Enabled unsolicited responses on widget 27
KERN: hda: UNMUTE/SET OUTPUT GAIN widget 16 (offset 74)
KERN: hda: ENABLE pin widget 25
KERN: hda: ENABLE pin widget 28
KERN: hda: ENABLE pin widget 29
KERN: hda: ENABLE EAPD pin widget 29
KERN: hda: ENABLE pin widget 31
KERN: hda: ENABLE pin widget 32
KERN: hda: ENABLE pin widget 34
KERN: hda: UNMUTE/SET INPUT GAIN widget 20 (offset 74)
KERN: hda: UNMUTE/SET OUTPUT GAIN widget 23 (offset 0)
KERN: hda: input vref 50 enabled
KERN: hda: input vref 80 enabled
KERN: hda: ENABLE pin widget 26
KERN: hda: ENABLE pin widget 27
KERN: hda: ENABLE EAPD pin widget 27
KERN: hda: ENABLE pin widget 30
KERN: hda: streams playback 0xffffffff8fdfb0b8, record 0xffffffff900e9480
KERN: hda: sensed pin widget 25, 0
KERN: looking for settings file
KERN: hda: sample size 4, num channels 2, buffer length 10240
KERN: hda: hda_stream_setup_buffers: setup stream 1: SR=192000, SF=24 F=0x1831 (0x100)
KERN: hda: hda_stream_setup_buffers(Playback): Allocated 163840 bytes for 2 buffers
KERN: hda: hda_stream_setup_buffers(Playback): Allocated 4096 bytes for 2 BDLEs
KERN: hda: stream: 1 fifo size: 1024 num_io_widgets: 1
KERN: hda: widgets: 16
KERN: hda: sample size 4, num channels 2, buffer length 6144
KERN: hda: hda_stream_setup_buffers: setup stream 2: SR=96000, SF=24 F=0x831 (0x100)
KERN: hda: hda_stream_setup_buffers(Recording): Allocated 98304 bytes for 2 buffers
KERN: hda: hda_stream_setup_buffers(Recording): Allocated 4096 bytes for 2 BDLEs
KERN: hda: stream: 2 fifo size: 256 num_io_widgets: 1
KERN: hda: widgets: 20
KERN: hda_stream_start() offset 80
KERN: hda_stream_start() offset 0
KERN: /dev/net/atheros813x/0: media change, media 0x900026 quality 1000 speed 10000000
KERN: register_domain(4, link)
For the keyboard, there is an iroster command that lets you enable or disable each device separately, with iroster -"Foo" or with + to enable. But it does not persist across reboots.
thanks for listening. I’ll give you more information about the command.
