Thinkpad E595 wifi issues
Ok, good and bad news!
Good is, disabling tpm2.0 from bios did some effect. Now haiku can see my wifi device.
Bad is, it can not find any reachable wifi.
Similar story for bluetooth. It does say “unknown|serverfailed” under bluetooth.
Bluetooth is far to be fully operational, only association works and you need to have a supported device. So, don’t worry about it.
I have this card in my Lenovo TP Yoga 11e. It seemed like it was going to work at first, but was unable to connect to my WPA2 network with a password. However, from the second boot onwards, the card is detected but it does not see any networks.
I also tried connecting from the command line with ifconfig, but it never successfully connects.
I’m on bleeding edge nightly build with this system.
I had the same problem in a similar Lenovo laptop, and this did the trick for me:
arp -d <router_ip>
