As an aside, I did some digging into how Android uses the Binder, and was a little amazed to find that it’s involved in just about everything! Window management, program launching and so on. Kudos to Dianne H.!
So I guess, given the right environment, scripting/IPC is still a concept in the present era!
Regarding Amiga and its “AREXX” ports, the ports are used more often than the language that spawned them. My favorite implementation was a visual language called the AmigaVision flow editor. For an excerpt of “The Computer Chronicles” about it see https://youtu.be/u7KIZQzYSls . The video doesn’t show the interprocess communication but it shows the language.
Heh – that brings back memories! Tim Bajarin still shows up sometimes as a guru on the local news. Looks a bit different now!
As I remember (dimly), ‘AREXX Ports’ were just standard Amiga MsgPorts, but with a specific packet format so that client and server could understand each other. As such they suffered from the same problem that if a server quit or died, a connected client would crash if it tried to send a message.
And there seems to be another copy here which has maybe had some build fixes added:
I think Barrett has a point and we should at least take a look and learn some from this. It doesn’t mean we have to use the code but it does represent what the Be engineers were thinking for a new BeOS API, so it might make sense to let it influence ideas about Haiku R2.
I still think there is a lot of room for operating system innovation and Haiku could be part of that.
