“hybrid kernel” is a meaningless marketing term. Haiku has a conventional monolithic kernel design.
[quote]
If you want to argue with the devs you can, but considering they wrote it and thats what they refer to it as being. I will take there word on it over yours.[/quote]
Can you cite where “the devs” en masse agree with this?
What comparison? “microkernel” does not mean “it’s smaller”. The purpose of the µkernel design is to put the very minimum of components into the privileged “Ring 0”, Haiku doesn’t even attempt to do this. BeOS made one gesture in this direction, running the network protocols in userspace, but Haiku reverses even this difference because of the lousy performance.
You’d have to define “rarely” in a very strange way to support this claim.
[quote]Really they are ? thats news to me becuase I can delete them while the system is running and geuss what, nothing happens. the media server shuts down and throw a debug warning. Thats about it.
try that on a linux system and get back to me.[/quote]
You can delete the driver files and the Haiku kernel (rather amusingly) treats this as a request to unload the driver. So then you have no more driver and sound comes to a stop.
In Linux deleting the driver files just removes the files from disk. The kernel is unaffected. Music (if you happened to be playing some) continues as before. If you want to unload the driver, you can do this explicitly, but you need to stop the music first.
I don’t think Haiku’s approach here is the Right Thing™, anyone who understands the driver dependencies well enough to know whether removing this or that file will actually have the desired effect, also understands enough to manually unload a driver. For ordinary users the behaviour is just mysterious, sometimes you can “upgrade” a driver by replacing one file, sometimes a complicated dance is needed. In the end most of them will reboot to see if it works.
[quote]
there is a issue with opensound and native drivers. But thats more of a problem with open sound and they can coexist just fine. In haiku selecting a driver is as easy as opening the media prefernces and selecting the driver and restarting the media server. I think you knowledge of the audio capabilitys is generally overstated.[/quote]
I explained exactly why the problem occurs already. The process you call “selecting a driver” doesn’t actually choose which kernel audio driver is loaded but only which of the kernel drivers will be used by default by Haiku’s system mixer. You can see the equivalent preferences panel in many other operating systems, except that it’s not necessary to “restart” anything. I can choose my Bluetooth headset, the music continues playing seamlessly and then I can walk away from the PC. Perhaps one day Haiku will be able to do this too.
