Submission issue
i actually tried to enable werror in intel22x folder , i removed the # and compiled that specific intel22x folder it turns out somebody has fixed the warning in the folder and forgot to to remove the # in the build/jam/ArchitectureRules and i changed it in my local repository and tried to make a patch i tried multiple ways to submit it but it failed in every way can anyone help me to submit this patch
Making sure you're not a bot! this is ticket
You are trying to push change request using git https access.
It won’t work.
You needs to get ssh access for that. More details here, looks for the section “Setup an account on Gerrit”:
Your remote URL should looks like this:
ssh://<your_gerrit_username>@git.haiku-os.org/haiku
Last but not least, you must have added your public SSH key(s) to your Gerrit profile.
Beware, you share in your screenshot an URL, in last line, with both your username and password visible in plain text.
I strongly suggest to:
  • change your password of your account on Gerrit.
  • remove or edit this screenshot so you don’t leak personal security data
Oh thanks for noticing it :smiling_face: I edited the picture
as an additional piece of info, the “-o topic” stuff isn’t neccesary. Unless you are working on a big chain of patches feeel free to omit it.
oh i saw that advice from a chat in irc channel
