Strange browser issues - Haiku Nightly 64 bit
Ahoy haikunauts,
I wanna ask about the following …
Is anyone experienced a similar issue as just once
a multiple dozens of new tabs opens superfast automatically
in Webpositive
and
in Falkon
… after upgrade from hrev58562 to hrev58572 ?
I had to close almost a hundred empty tabs in both browsers …
… after I successfully downgraded and rebooted into hrev58562
On hrev58572 I could not stop this ‘opening of new tabs’, just killed the applications.
HERE you are the Webpositive debug log (on a temporary file upload/share)
I appreciate an answer from you - if you experienced similar …
or just my install behaves so …!
Thanks in advance -
Finally I upgraded
to hrev58583 from the downgraded Nightly - hrev58562 -
as I got the same issue - many empty tabs opened - but actually for Falkon only. This way I disclosed Haiku upgrade as a cause of the issue.
This way I modified the title as well.
Now I watch for any signs of strange behaviours …
… still not experienced such annoying storm of tabs lately!..
I’m not sure what you encountered, but regardless for errors of webkit/webpositive please open a ticket on the bug tracker.
