I remember reading that it could at least get into the kernel on PowerPC Apple, and I know of the AI-based Tabby PPC, but in Haiku main, has there been any strides to get to the desktop?
on download.haiku-os.org the link for ppc is gone
maybe it has been abandoned, but im not a developer so dont take my word for it
theres also this link saying how to compile haiku on ppc. maybe you can try it?
Hi, Yes we continue to work on it. But have no big “flashy” things to show yet ![]()
If you want to contritbute to the effort feel free to send me a pm
Is the kernel at all booting?
I would be interested in looking into maybe attempting something, else being a tester; my hardware is a iMac G3 Graphite, 600mhz, 768MB of RAM, and a ATI Rage 128 at ~16mb of VRAM
with some patches, the kernel will get to the virtual memory initialization, where it then throws you into the KDL, which is not initialzed at that point
Oh that’s exciting, how hard do you think it’d be to fix that you think?
Thanks to mention it - I had not recognized until now.
It might happened as there are many AI helped development fork arised and shown as reached Desktop and some run on older Apple machines .. and should not be mixed with the Haiku developers’ developed one. That was lesser user ready to run, rather development purposes install image, so maybe this way was the link removed to not download and be disappointed with it.
I’m pretty sure Haiku doesn’t delete anything because a fork exists,but rather because it simply doesn’t work (boot to desktop) or maybe the build got broken so that new downloads can’t be built right now.
If anyone fixes the PowerPC port,it surely will be added to the download section again.
Did PowerPC ever boot to Desktop?
I never knew if it did or didn’t, I did know about the downloads being there, though.
No,the PowerPC port was never in a usable state.
There were experimental builds,that’s correct,but they didn’t really work.
It was a way to easily try out how far it gets and maybe improve things if you have the needed knowledge.
The SPARC port that is still available for download also never worked as far as I know.
And the ARM/ARM64 ports were available as downloads years ago already,when they also didn’t work (but maybe they do now on specific hardware,I’m not sure about the current state).
I see.
I do want to personally take a look at what the PPC version looks like at the moment, I do wonder if we can cleanroom Tabby/PPC’s patches into Haiku main, as in rough out what it does and make a better, non-AI implementation; given how it actually makes it TO the Desktop on a G3.
Hey, PowerPC should compile, right?
Not run, just compile to a ISO.
At least it did when the downloads were still available.
Maybe it broke and that was the reason the downloads were removed,maybe it still works.
You’ll have to try.
I did try, no idea if i did something wrong, but it fails
If you share the relevant section of your console output (the part that contains the error message and which file it comes from),I can probably find out if that’s a problem in the code or you did something wrong.
I’m just trying to compile base Haiku, I might just re-git the codebase, as I have a feeling it’s because I had it moved from a exFAT drive to ext4.
don't know how to make objects/haiku/ppc/packaging/repositories/HaikuPortsCross-build/packages/icu74_bootstrap-74.1-1-ppc.hpkg is the error I currently have.
Unless doing a basic git clone isnt well suited for this project.
I just want to get Haiku PPC compiled to see what happens, then I want to try doing a clean reimplementation of what Tabby does, but without the AI nonsense, or at least follow its steps; so it can be possibly pushed to main.
I see PowerPC Haiku as valuable, since it could open the door to even more BeOS Software preservation.
Haiku heavily relies on filesystem attributes,that’s also the case during compiling.
On filesystems without support for that (should be the case for both exFAT and ext4) it creates additional files for storing attributes within the files.
It could be that it somehow got confused by switching filesystems,but could also be unrelated.
Doing a git clone is the correct way to get the source,but it’s important that you also get it from the right server.
The mirrors on Codeberg and Github don’t have the hrev tags which are important for the build,so you should always clone from Haikus own server: git clone https://review.haiku-os.org/haiku.
I don’t want to stop you from your work,but please note that Haiku for PowerPC has no ABI compatibility to BeOS like the 32bit x86 version has.
If you get it to work,it can only run applications compiled for Haiku for PowerPC,not old BeOS PowerPC applications.
Will re-clone from haiku’s server
Also yeah I figured there isn’t a BeOS ABI yet, but one could be made in the future, and one should be made in the future.
I only want to make a attempt to get it working, else if someone else is trying, test their work.
It will be very difficult to make ABI compatibility for that.
In the x86 version,we still need to use the old GCC2 compiler to compile important system libraries,so that their resulting binaries are ABI-compatible to BeOS,which also used GCC2.
That’s still possible today because GCC2 is open-source software that we can still use and even patch in case something ever breaks there.
The PowerPC version of BeOS,however,never used GCC but an commercial closed-source compiler called Metrowerks Compilers.
See for more details: BeOS for PowerPC didn't use GCC. It used the Metrowerks Compilers (mwcc etc). On... | Hacker News
To make Haiku PowerPC ABI-compatible to BeOS,we’d have to compile the same important system libraries with Metrowerks Compilers that we compile with GCC2 on x86.
The company that created it doesn’t exist anymore and relying on a 30 year old closed-source program that we can not patch if something breaks isn’t safe for the future.
