Have you mesa_swpipe and llvm_libs installed?
They are installed:
- mesa_swpipe version 17.1.7-3
- llvm_libs version 5.0.0-1
Could it be the BGLRenderer code has been moved to a different library? Is it no more in libGL.so (or the versioned one, not a problem since libGL.so is a symlink)?
EDIT: Maybe mesa changed something? This is the BGLView construction call. I see nothing out of the ordinary here.
BGLView(frame, âglviewâ, B_FOLLOW_ALL, B_WILL_DRAW, BGL_RGB | BGL_DOUBLE | BGL_DEPTH | BGL_STENCIL);
Sounds like installed renderer fail to link against libgl to get BGLRenderer class.
Could you dump your haiku hrev ? x86_64 ?
Letâs see⌠this should be âhaiku r1~alpha4_pm_hrev51479-1â⌠and x86_64
âappsâ is for use by self-containeg apps, where there is just a single executable or everything is stored in the same directory. âbinâ is used for command line things and in general for everything that uses a somewhat unixy organization of the filesystem. The distinction is quite blurry, however.
Var and cache are as on Linux, but I donât think we have automatic cleanup in place yet
Okay, It seems I missed a link time library when switching to autoconf by Mesa. Somehow it doesnât happen with GLTeapot.
I pushed a fix at Haikuports.
Is it possible for Mesa to be multi-threaded and use multiple processors? Modern CPUs such as AMD Zen have 8 cores. If Mesa could use multiple cores, it could be significantly faster. OK, looks like Gallium llvmpipe does support multiple cores: https://www.mesa3d.org/llvmpipe.html
Both llvmpipe and new kid/software rasterizer on the block, openswr, have multithreaded rendering now.
https://www.phoronix.com/scan.php?page=article&item=llvmpipe-swr-xeon&num=1
I dunno if it worth it for us to port openswr backend to Haiku yet.
When will the fix appear in the nightly builds? I update today and it is still broken so I assume it takes longer to get the fix into haiku.
Itâs now pushed in the repository. For nightlies, wait until tomorrow.
Dunno, but what you can do is building latest mesa package directly from haikuports.
And upgrade mesa + swpipe packages from freshly built packagesâŚ
I prefer waiting for nightly builds. Itâs better to test against an âofficialâ build than messing around. Makes it hard for maintainers to accurately fix a problem if people nilly-willy compile on their own.
EDIT: The fix is working. One problem less.
