Split Screen
Just installed the newest nightly and the screen is split. About 1/4 of the left side of the screen appears on the right side. The remaining 3/4 of the screen (the right side) is on the left. So, when you drag your mouse off the left edge it appears to be coming in from the right edge of the screen.
incompatible video driver? known problem?
No idea what the onboard chipset for this motherboard is. found it laying around in the back.
Hi mbond,
I’d guess it’s graphics driver related, too…
You should file a ticket for it. Make sure to include all the info you can, see ReportingBugs (see “syslog” and “Hardware issues”).
Regards,
Humdinger
I had encountered the same issue with Alpha1R3 on Thinkpads T42 and T43 (the regular 14.1" LCDs). This may help narrowing the nature of the issue.
So that you know, Thinkpads T60/T61, T4x0, and T5x0 do not exhibit this issue.
I have not tried again on T42/T43 with Alpha1R4.
The ‘stable’ Alpha 1 R4 doesn’t exhibit this problem.
However, as soon as I click on the screen in the ‘stable’ release it kernel panics.
The nightly seems to function properly, with the exception of the split screen.
Welcome to the Haiku shell.
~> listdev
~> listimage | grep accel
hrev46642 gcc4\2
http://i031.radikal.ru/1402/2d/ca95da8fa066.png
https://www.haiku-os.org/docs/userguide/en/bootloader.html
Select fail safe video mode If you had to activate the option Use fail-safe video mode, you can set resolution and color depth.
hrev46791 gcc2/hybrid
listdev:
device Serial bus controller (SMBus) [c|5|0]
device 266a: 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller
device Mass storage controller (IDE interface) [1|1|8a]
device 266f: 82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller
device 2640: 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge
device Serial bus controller (FireWire (IEEE 1394), OHCI) [c|0|10]
vendor 104c: Texas Instruments
device 8024: TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link)
vendor 11ab: Marvell Technology Group Ltd.
device 4320: 88E8001 Gigabit Ethernet Controller
device Bridge (PCI bridge, Subtractive decode) [6|4|1]
device 244e: 82801 PCI Bridge
device Serial bus controller (USB controller, EHCI) [c|3|20]
device 265c: 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller
device Serial bus controller (USB controller, UHCI) [c|3|0]
device 265b: 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4
device 265a: 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3
device 2659: 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2
device 2658: 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1
device 2668: 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller
device 2582: 82915G/GV/910GL Integrated Graphics Controller
device Bridge (Host bridge) [6|0|0]
device 2580: 82915G/P/GV/GL/PL/910GL Memory Controller Hub
I installed an ATI card and the screen is now displaying properly.
The onboard card seems to be finiky at best … its likely an issue with it.
[quote=mbond]I installed an ATI card and the screen is now displaying properly.
The onboard card seems to be finiky at best … its likely an issue with it.[/quote]
