[SOLVED - without action taken] An iprowifi4965 reconnecting issue
Ahoy Haikunauts,
Just as upgraded Haiku x86_64 – from hrev58469 to hrev58475
I experienced that my wlan adapter started to reconnects really frequently.
I have a daily check command line where I filtering the lines with ‘error’ in syslog and syslog.old
When I first restarted after the upgrade my mobile router was attached via USB, and then I had no network at all … the network status applet was showed white lamp, nor yellow neither red.
Generally the mobile router this way works as an RNDIS network device - quite well. Builds up slowly a bit, but reliably - once or twice - earlier - I plugged out ethernet cable and switched off all radios with a button - and worked,: I could use the net further.
Now I was surprised, so finally unplugged the mobile router, and restarted Haiku.
Then both my ethernet and wlan connection became green and up, but the Intel wifi started to reconnecting frequently - just as many monthes before with still Beta4 when it was a valid issue.
This is what I could see in filtered syslog - from terminal - this is the second part of my terminal output.
…and after , the 3rdpart of my daily chech routine, is a check of my installed Haiku BFS health – output of ‘checkfs -c /boot’ command.
Finally, in 4th part, I looked at the last 300 lines of the syslog file to show what happens with the wlan adapter and my WiFi connection.
This is what I provided HERE below, others had to remove to fit into the post limit.
Do you have same experiences - after the upgrade, as in the title - with the same wlan adapter ?
~> tail -300 /boot/system/var/log/syslog
2024-12-28 22:50:40 KERN: /dev/net/iprowifi4965/0: link up, media 0x850098 quality 1000 speed 0
2024-12-28 22:50:40 KERN: wlan_control: 9235, 15
2024-12-28 22:50:40 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_REQUEST for 192.168.0.31 to 255.255.255.255:67
2024-12-28 22:50:40 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Received DHCP_NACK from 192.168.1.1
2024-12-28 22:50:40 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_DISCOVER to 255.255.255.255:67
2024-12-28 22:50:40 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] capabilities change: was 0xc11, now 0x911
2024-12-28 22:50:40 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Timeout shift: 500 msecs (try 1)
2024-12-28 22:50:40 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Timeout shift: 1000 msecs (try 2)
2024-12-28 22:50:40 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 22:50:41 KERN: wlan_control: 9235, 1
2024-12-28 22:50:41 KERN: wlan_control: 9235, 15
2024-12-28 22:50:41 KERN: wlan_control: 9234, 19
2024-12-28 22:50:41 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Timeout shift: 2000 msecs (try 3)
2024-12-28 22:50:41 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_DISCOVER to 255.255.255.255:67
2024-12-28 22:50:41 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Received DHCP_OFFER from 192.168.0.1
2024-12-28 22:50:41 DAEMON 'DHCP':   your_address: 192.168.0.31
2024-12-28 22:50:41 DAEMON 'DHCP':   server: 192.168.0.1
2024-12-28 22:50:41 DAEMON 'DHCP':   lease time: 86400 seconds
2024-12-28 22:50:41 DAEMON 'DHCP':   renewal time: 43200 seconds
2024-12-28 22:50:41 DAEMON 'DHCP':   rebinding time: 75600 seconds
2024-12-28 22:50:41 DAEMON 'DHCP':   subnet: 255.255.255.0
2024-12-28 22:50:41 DAEMON 'DHCP':   broadcast: 192.168.0.255
2024-12-28 22:50:41 DAEMON 'DHCP':   gateway: 192.168.0.1
2024-12-28 22:50:41 DAEMON 'DHCP':   nameserver[0]: 192.168.0.1
2024-12-28 22:50:41 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_REQUEST for 192.168.0.31 to 255.255.255.255:67
2024-12-28 22:50:41 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Received DHCP_ACK from 192.168.0.1
2024-12-28 22:50:41 DAEMON 'DHCP': /dev/net/iprowifi4965/0: DHCP status = No error
2024-12-28 22:50:41 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 22:50:46 KERN: Last message repeated 4 times.
2024-12-28 22:50:46 KERN: [net/iprowifi4965/0] ieee80211_ref_node (ht_send_action_ba_addba:3060) 0xffffffffbfb90000<54:1f:8d:86:70:ed> refcnt 4
2024-12-28 22:50:46 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 22:50:51 KERN: Last message repeated 4 times.
Last message repeated 16 times
2024-12-28 22:51:57 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 22:52:01 KERN: Last message repeated 4 times.
Last message repeated 9 times
2024-12-28 22:52:39 KERN: Last message repeated 3 times.
2024-12-28 22:52:39 KERN: usb error ehci 1: qtd (0xd43700) error: 0x00088d46
2024-12-28 22:52:40 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 22:52:45 KERN: Last message repeated 4 times.
Last message repeated 32 times
2024-12-28 22:54:57 KERN: Last message repeated 3 times.
2024-12-28 22:55:01 KERN: Last message repeated 4 times.
Last message repeated 11 times
2024-12-28 22:55:47 KERN: Last message repeated 3 times.
2024-12-28 22:55:47 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] recv deauthenticate (reason: 3 (sending STA is leaving/has left IBSS or ESS))
2024-12-28 22:55:47 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked:2760: starting state update RUN -> RUN (AUTH)
2024-12-28 22:55:47 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked: RUN -> AUTH (arg 960) (nrunning 0 nscanning 0)
2024-12-28 22:55:47 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb:2576: running state update RUN -> AUTH (1)
2024-12-28 22:55:47 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb: RUN -> AUTH arg 960
2024-12-28 22:55:47 KERN: [net/iprowifi4965/0] sta_newstate: RUN -> AUTH (960)
2024-12-28 22:55:47 KERN: ieee80211_notify_node_leave
2024-12-28 22:55:47 KERN: /dev/net/iprowifi4965/0: link down, media 0x50080 quality 1000 speed 0
2024-12-28 22:55:47 KERN: wlan_control: 9234, 20
2024-12-28 22:55:47 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_RELEASE to 192.168.0.1:67
2024-12-28 22:55:48 KERN: Last message repeated 2 times.
2024-12-28 22:55:48 KERN: wlan_control: 9234, 16
2024-12-28 22:55:48 KERN: wlan_control: 9234, 17
2024-12-28 22:55:48 KERN: wlan_control: 9234, 26
2024-12-28 22:55:48 KERN: wlan_control: 9234, 103
2024-12-28 22:55:48 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
Last message repeated 1 time
2024-12-28 22:55:49 KERN: ieee80211_notify_scan_done
2024-12-28 22:55:49 KERN: wlan_control: 9235, 76
2024-12-28 22:55:49 KERN: wlan_control: 9234, 18
2024-12-28 22:55:49 KERN: wlan_control: 9234, 7
2024-12-28 22:55:49 KERN: wlan_control: 9234, 95
2024-12-28 22:55:49 KERN: wlan_control: 9234, 17
2024-12-28 22:55:49 KERN: wlan_control: 9234, 26
2024-12-28 22:55:49 KERN: wlan_control: 9234, 21
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] station assoc via MLME
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_alloc_node 0xffffffffbfef8000<54:1f:8d:86:70:ed> in station table
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] ieee80211_alloc_node: inact_reload 2
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] switch station to HT40 channel 5180/0x220340
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] node_reclaim: remove 0xffffffffbfb90000<54:1f:8d:86:70:ed> from station table, refcnt 0
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] set WME_AC_BE (chan) [acm 0 aifsn 3 logcwmin 4 logcwmax 10 txop 0]
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] set WME_AC_BE (bss ) [acm 0 aifsn 3 logcwmin 4 logcwmax 10 txop 0]
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] set WME_AC_BK (chan) [acm 0 aifsn 7 logcwmin 4 logcwmax 10 txop 0]
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] set WME_AC_BK (bss ) [acm 0 aifsn 7 logcwmin 4 logcwmax 10 txop 0]
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] set WME_AC_VI (chan) [acm 0 aifsn 2 logcwmin 3 logcwmax 4 txop 94]
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] set WME_AC_VI (bss ) [acm 0 aifsn 2 logcwmin 3 logcwmax 4 txop 94]
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] set WME_AC_VO (chan) [acm 0 aifsn 2 logcwmin 2 logcwmax 3 txop 47]
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] set WME_AC_VO (bss ) [acm 0 aifsn 2 logcwmin 2 logcwmax 3 txop 47]
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] update WME_AC_BE (chan+bss) [acm 0 aifsn 2 logcwmin 4 logcwmax 10 txop 0]
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_wme_updateparams_locked: WME params updated, cap_info 0xfe
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_sta_join1 0xffffffffbfef8000<54:1f:8d:86:70:ed> AUTH -> AUTH, FC0_SUBTYPE_DEAUTH
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked:2760: starting state update AUTH -> AUTH (AUTH)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked: AUTH -> AUTH (arg 192) (nrunning 0 nscanning 0)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb:2576: running state update AUTH -> AUTH (1)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb: AUTH -> AUTH arg 192
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] sta_newstate: AUTH -> AUTH (192)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_ref_node (ieee80211_send_mgmt:2712) 0xffffffffbfef8000<54:1f:8d:86:70:ed> refcnt 3
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ni 0xffffffffbfef8000 vap 0xffffffffbac7c000 mode STA state AUTH m 0xffffffffbafd5300 status 0
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ni 0xffffffffbfef8000 mode STA state AUTH arg 0x0000000000000002 status 0
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] recv auth frame with algorithm 0 seq 2
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked:2760: starting state update AUTH -> AUTH (ASSOC)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked: AUTH -> ASSOC (arg 0) (nrunning 0 nscanning 0)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb:2576: running state update AUTH -> ASSOC (1)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb: AUTH -> ASSOC arg 0
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] sta_newstate: AUTH -> ASSOC (0)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ni 0xffffffffbfef8000 vap 0xffffffffbac7c000 mode STA state ASSOC m 0xffffffffe4247650 status 0
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ni 0xffffffffbfef8000 mode STA state ASSOC arg 0x0000000000000003 status 0
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_parse_wmeparams: WME: 0: acm=0 aifsn=3 logcwmin=4 logcwmax=10 txopLimit=0
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_parse_wmeparams: WME: 1: acm=0 aifsn=7 logcwmin=4 logcwmax=10 txopLimit=0
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_parse_wmeparams: WME: 2: acm=0 aifsn=2 logcwmin=3 logcwmax=4 txopLimit=94
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_parse_wmeparams: WME: 3: acm=0 aifsn=2 logcwmin=2 logcwmax=3 txopLimit=47
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_wme_updateparams_locked: WME params updated, cap_info 0x0
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] assoc success at aid 1: short preamble, short slot time, QoS, HT40 (+AMPDU) (+AMSDU)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked:2760: starting state update ASSOC -> ASSOC (RUN)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked: ASSOC -> RUN (arg 16) (nrunning 0 nscanning 0)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb:2576: running state update ASSOC -> RUN (1)
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb: ASSOC -> RUN arg 16
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] sta_newstate: ASSOC -> RUN (16)
2024-12-28 22:55:49 KERN: ieee80211_notify_node_join
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] ieee80211_node_authorize: inact_reload 20
2024-12-28 22:55:49 KERN: /dev/net/iprowifi4965/0: link up, media 0x850098 quality 1000 speed 0
2024-12-28 22:55:49 KERN: wlan_control: 9235, 15
2024-12-28 22:55:49 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_REQUEST for 192.168.0.31 to 255.255.255.255:67
2024-12-28 22:55:49 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] capabilities change: was 0xc11, now 0x911
2024-12-28 22:55:49 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Received DHCP_NACK from 192.168.1.1
2024-12-28 22:55:49 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_DISCOVER to 255.255.255.255:67
2024-12-28 22:55:50 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Timeout shift: 500 msecs (try 1)
2024-12-28 22:55:50 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_DISCOVER to 255.255.255.255:67
2024-12-28 22:55:50 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 22:55:50 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Timeout shift: 1000 msecs (try 2)
2024-12-28 22:55:50 KERN: wlan_control: 9235, 1
2024-12-28 22:55:50 KERN: wlan_control: 9235, 15
2024-12-28 22:55:50 KERN: wlan_control: 9234, 19
2024-12-28 22:55:51 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 22:55:51 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Timeout shift: 2000 msecs (try 3)
2024-12-28 22:55:51 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_DISCOVER to 255.255.255.255:67
2024-12-28 22:55:51 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Received DHCP_OFFER from 192.168.0.1
2024-12-28 22:55:51 DAEMON 'DHCP':   your_address: 192.168.0.31
2024-12-28 22:55:51 DAEMON 'DHCP':   server: 192.168.0.1
2024-12-28 22:55:51 DAEMON 'DHCP':   lease time: 86400 seconds
2024-12-28 22:55:51 DAEMON 'DHCP':   renewal time: 43200 seconds
2024-12-28 22:55:51 DAEMON 'DHCP':   rebinding time: 75600 seconds
2024-12-28 22:55:51 DAEMON 'DHCP':   subnet: 255.255.255.0
2024-12-28 22:55:51 DAEMON 'DHCP':   broadcast: 192.168.0.255
2024-12-28 22:55:51 DAEMON 'DHCP':   gateway: 192.168.0.1
2024-12-28 22:55:51 DAEMON 'DHCP':   nameserver[0]: 192.168.0.1
2024-12-28 22:55:51 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_REQUEST for 192.168.0.31 to 255.255.255.255:67
2024-12-28 22:55:51 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Received DHCP_ACK from 192.168.0.1
2024-12-28 22:55:51 DAEMON 'DHCP': /dev/net/iprowifi4965/0: DHCP status = No error
2024-12-28 22:55:56 KERN: Last message repeated 4 times.
2024-12-28 22:55:56 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 22:55:56 KERN: [net/iprowifi4965/0] ieee80211_ref_node (ht_send_action_ba_addba:3060) 0xffffffffbfef8000<54:1f:8d:86:70:ed> refcnt 4
2024-12-28 22:55:57 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 22:56:02 KERN: Last message repeated 4 times.
Last message repeated 28 times
2024-12-28 22:57:58 KERN: Last message repeated 3 times.
2024-12-28 22:58:02 KERN: Last message repeated 4 times.
Last message repeated 43 times
2024-12-28 23:00:56 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 23:00:58 KERN: Last message repeated 2 times.
2024-12-28 23:00:58 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] recv deauthenticate (reason: 3 (sending STA is leaving/has left IBSS or ESS))
2024-12-28 23:00:58 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked:2760: starting state update RUN -> RUN (AUTH)
2024-12-28 23:00:58 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked: RUN -> AUTH (arg 960) (nrunning 0 nscanning 0)
2024-12-28 23:00:58 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb:2576: running state update RUN -> AUTH (1)
2024-12-28 23:00:58 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb: RUN -> AUTH arg 960
2024-12-28 23:00:58 KERN: [net/iprowifi4965/0] sta_newstate: RUN -> AUTH (960)
2024-12-28 23:00:58 KERN: ieee80211_notify_node_leave
2024-12-28 23:00:58 KERN: /dev/net/iprowifi4965/0: link down, media 0x50080 quality 1000 speed 0
2024-12-28 23:00:58 KERN: wlan_control: 9234, 20
2024-12-28 23:00:58 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_RELEASE to 192.168.0.1:67
2024-12-28 23:00:58 KERN: wlan_control: 9234, 16
2024-12-28 23:00:58 KERN: wlan_control: 9234, 17
2024-12-28 23:00:58 KERN: wlan_control: 9234, 26
2024-12-28 23:00:58 KERN: wlan_control: 9234, 103
2024-12-28 23:00:58 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 23:01:00 KERN: ieee80211_notify_scan_done
2024-12-28 23:01:00 KERN: wlan_control: 9235, 76
2024-12-28 23:01:00 KERN: wlan_control: 9234, 18
2024-12-28 23:01:00 KERN: wlan_control: 9234, 7
2024-12-28 23:01:00 KERN: wlan_control: 9234, 95
2024-12-28 23:01:00 KERN: wlan_control: 9234, 17
2024-12-28 23:01:00 KERN: wlan_control: 9234, 26
2024-12-28 23:01:00 KERN: wlan_control: 9234, 21
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] station assoc via MLME
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_alloc_node 0xffffffffbff78000<54:1f:8d:86:70:ed> in station table
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] ieee80211_alloc_node: inact_reload 2
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] switch station to HT40 channel 5180/0x220340
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] node_reclaim: remove 0xffffffffbfef8000<54:1f:8d:86:70:ed> from station table, refcnt 0
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] set WME_AC_BE (chan) [acm 0 aifsn 3 logcwmin 4 logcwmax 10 txop 0]
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] set WME_AC_BE (bss ) [acm 0 aifsn 3 logcwmin 4 logcwmax 10 txop 0]
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] set WME_AC_BK (chan) [acm 0 aifsn 7 logcwmin 4 logcwmax 10 txop 0]
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] set WME_AC_BK (bss ) [acm 0 aifsn 7 logcwmin 4 logcwmax 10 txop 0]
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] set WME_AC_VI (chan) [acm 0 aifsn 2 logcwmin 3 logcwmax 4 txop 94]
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] set WME_AC_VI (bss ) [acm 0 aifsn 2 logcwmin 3 logcwmax 4 txop 94]
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] set WME_AC_VO (chan) [acm 0 aifsn 2 logcwmin 2 logcwmax 3 txop 47]
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] set WME_AC_VO (bss ) [acm 0 aifsn 2 logcwmin 2 logcwmax 3 txop 47]
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] update WME_AC_BE (chan+bss) [acm 0 aifsn 2 logcwmin 4 logcwmax 10 txop 0]
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_wme_updateparams_locked: WME params updated, cap_info 0xfe
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_sta_join1 0xffffffffbff78000<54:1f:8d:86:70:ed> AUTH -> AUTH, FC0_SUBTYPE_DEAUTH
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked:2760: starting state update AUTH -> AUTH (AUTH)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked: AUTH -> AUTH (arg 192) (nrunning 0 nscanning 0)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb:2576: running state update AUTH -> AUTH (1)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb: AUTH -> AUTH arg 192
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] sta_newstate: AUTH -> AUTH (192)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_ref_node (ieee80211_send_mgmt:2712) 0xffffffffbff78000<54:1f:8d:86:70:ed> refcnt 3
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ni 0xffffffffbff78000 vap 0xffffffffbac7c000 mode STA state AUTH m 0xffffffffe40f3748 status 0
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ni 0xffffffffbff78000 mode STA state AUTH arg 0x0000000000000002 status 0
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] recv auth frame with algorithm 0 seq 2
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked:2760: starting state update AUTH -> AUTH (ASSOC)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked: AUTH -> ASSOC (arg 0) (nrunning 0 nscanning 0)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb:2576: running state update AUTH -> ASSOC (1)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb: AUTH -> ASSOC arg 0
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] sta_newstate: AUTH -> ASSOC (0)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ni 0xffffffffbff78000 vap 0xffffffffbac7c000 mode STA state ASSOC m 0xffffffffbafd6808 status 0
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ni 0xffffffffbff78000 mode STA state ASSOC arg 0x0000000000000003 status 0
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_parse_wmeparams: WME: 0: acm=0 aifsn=3 logcwmin=4 logcwmax=10 txopLimit=0
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_parse_wmeparams: WME: 1: acm=0 aifsn=7 logcwmin=4 logcwmax=10 txopLimit=0
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_parse_wmeparams: WME: 2: acm=0 aifsn=2 logcwmin=3 logcwmax=4 txopLimit=94
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_parse_wmeparams: WME: 3: acm=0 aifsn=2 logcwmin=2 logcwmax=3 txopLimit=47
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_wme_updateparams_locked: WME params updated, cap_info 0x0
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] assoc success at aid 1: short preamble, short slot time, QoS, HT40 (+AMPDU) (+AMSDU)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked:2760: starting state update ASSOC -> ASSOC (RUN)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_new_state_locked: ASSOC -> RUN (arg 16) (nrunning 0 nscanning 0)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb:2576: running state update ASSOC -> RUN (1)
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] ieee80211_newstate_cb: ASSOC -> RUN arg 16
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] sta_newstate: ASSOC -> RUN (16)
2024-12-28 23:01:00 KERN: ieee80211_notify_node_join
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] ieee80211_node_authorize: inact_reload 20
2024-12-28 23:01:00 KERN: wlan_control: 9235, 15
2024-12-28 23:01:00 KERN: /dev/net/iprowifi4965/0: link up, media 0x850098 quality 1000 speed 0
2024-12-28 23:01:00 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_REQUEST for 192.168.0.31 to 255.255.255.255:67
2024-12-28 23:01:00 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Received DHCP_NACK from 192.168.1.1
2024-12-28 23:01:00 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_DISCOVER to 255.255.255.255:67
2024-12-28 23:01:00 KERN: [net/iprowifi4965/0] [54:1f:8d:86:70:ed] capabilities change: was 0xc11, now 0x911
2024-12-28 23:01:00 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Timeout shift: 500 msecs (try 1)
2024-12-28 23:01:00 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 23:01:00 CRON 'crond'[64997]: (user) CMD (run-parts /boot/system/settings/cron.hourly)
2024-12-28 23:01:00 CRON 'crond'[64996]: (user) CMDEND (run-parts /boot/system/settings/cron.hourly)
2024-12-28 23:01:00 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Timeout shift: 1000 msecs (try 2)
2024-12-28 23:01:01 KERN: wlan_control: 9235, 1
2024-12-28 23:01:01 KERN: wlan_control: 9235, 15
2024-12-28 23:01:01 KERN: wlan_control: 9234, 19
2024-12-28 23:01:01 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 23:01:01 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Timeout shift: 2000 msecs (try 3)
2024-12-28 23:01:01 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_DISCOVER to 255.255.255.255:67
2024-12-28 23:01:01 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Received DHCP_OFFER from 192.168.0.1
2024-12-28 23:01:01 DAEMON 'DHCP':   your_address: 192.168.0.31
2024-12-28 23:01:01 DAEMON 'DHCP':   server: 192.168.0.1
2024-12-28 23:01:01 DAEMON 'DHCP':   lease time: 86400 seconds
2024-12-28 23:01:01 DAEMON 'DHCP':   renewal time: 43200 seconds
2024-12-28 23:01:01 DAEMON 'DHCP':   rebinding time: 75600 seconds
2024-12-28 23:01:01 DAEMON 'DHCP':   subnet: 255.255.255.0
2024-12-28 23:01:01 DAEMON 'DHCP':   broadcast: 192.168.0.255
2024-12-28 23:01:01 DAEMON 'DHCP':   gateway: 192.168.0.1
2024-12-28 23:01:01 DAEMON 'DHCP':   nameserver[0]: 192.168.0.1
2024-12-28 23:01:01 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Send DHCP_REQUEST for 192.168.0.31 to 255.255.255.255:67
2024-12-28 23:01:01 DAEMON 'DHCP': /dev/net/iprowifi4965/0: Received DHCP_ACK from 192.168.0.1
2024-12-28 23:01:01 DAEMON 'DHCP': /dev/net/iprowifi4965/0: DHCP status = No error
2024-12-28 23:01:06 KERN: Last message repeated 4 times.
2024-12-28 23:01:06 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 23:01:06 KERN: [net/iprowifi4965/0] ieee80211_ref_node (ht_send_action_ba_addba:3060) 0xffffffffbff78000<54:1f:8d:86:70:ed> refcnt 4
2024-12-28 23:01:07 KERN: check_sense: encountered DEFERRED ERROR - bye, bye
2024-12-28 23:01:12 KERN: Last message repeated 4 times.
Kind regards,
Ok. so seems noone else experienced similar issue until now …
then this post fullfilled its purpose.
Today it had stopped for me too, so maybe the repeater or the router of the rbuilding or even the mobile router caused this issue, and the experienced issue was only coincidence.
It was good to ask about it - this way I spared an unnecessary ticket.
Kind regards,
I have seen this same problem with about every machine i have here that has an iprowifi4965, they periodically just disconnect and reconnect for no apparent reason, regardless of what access point they connect to. I have seen this same behavior for years so its not a recent thing.
Yepp, it was for a very long period when was turned Beta3 to Beta4, but then many upgrade happened and in case Beta4 I had no issues with iprowifi4965 in my Dell Precision M6700, nor Nightly neither Beta4/Beta5. I was quite happy how reliably worked for me.
Actually I have no such issue - it had stopped after two days.
I admit I do not use again the ZTE mobile router in my flat. It is switched off now. I suspect maybe it had caused the error I experienced this time.
