Hiya… first of all, amazing work to all the devs and contributors of other work… I loved BeOS in the late 90s, and while i’ve checked in with Haiku over the years it seems its now at a state that I can actually use and have fun with on a second ‘dev’ machine here. Awesome work.
Now for the puzzling part, i’ll try and be brief… (EDIT: guess i massively failed in that endeavour)
I successfully installed Haiku the other day on an old 30gb (yes 30gb, lol) SSD I had laying around, just to try it out. This is on an old AMD Athlon II X2 220 system, with 8gb ram. I’ll be using this mostly to play with Haiku, and also as a serial monitor for Amiga dev hardware work over a null modem cable. Everything went swimmingly. Even falkon played nice most of the time.
I decided I would do the system over with a 120gb SSD, so I could perhaps dual-boot ReactOS and AROS and the like to try other hobby OS’s at a later stage. Note that all other specs are the same, and none of these other systems are installed.
The SSD in question was picked up second hand - CeX (UK second hand store) failed to wipe the disk of the previous users data, which is crazy to me, but it had a previous Windows installation. I wiped it with diskpart on another system using the ‘clean’ command before continuing.
Installation is fine, but now I get the dreaded ‘stage1: failed to load OS’ message. Things I made sure I did are:
- Initialised the disk with ‘Intel Partition Table’ in the disk-setup-thingy
- Made the partition Active in the Haiku disk-setup-whatsit
- Formatted to Be filesystem.
Things I have also tried after searching around:
- writembr to the raw disk dev
- makebootable to the Haiku partition (thought it was worth a try)
- Shouting
- Some UEFI boot manager setup tutorial I was following before realising the board is of course not UEFI
- Swearing
I have even tried starting everything from scratch… re-‘cleaning’ the drive, even re-writing the USB flash. The only thing i’m doing differently to the install on the other SSD (which is no longer in the sytem btw), is to install to a 30GB partition, rather than the full disk.
I have a feeling this all may be something to do with the previous owners installation of Windows on the new SSD, and perhaps i’m missing something obvious?
Any help would be appreciated…
Many thanks and again, awesome work!
John
