Solution for partial updates?
i’ve already found the topic as feature request in the forum, but is there already a solution to make partial/controlled updates? background: i would like to update apps or nightly packages individually, to evaluate where problems arise.
with the current update model and full updates, i usually stuck with a broken system.
pkgman update package_name
thank you – this is easy :slight_smile:
