Looks like you already done the hard part, now creating a recipe for it?
xaralx-0.7-1-x86_64.hpkg
A recipe already done too. ![]()
thanks for replying.
sadly I use chinese, not japanese
becjk’s last update was more than 10 years ago. it does not work nomally in haiku now
Well, for this topic we needs someone who both is a developer and understands CKJ.
Hopefully, with a bigger audience than 10 years ago, maybe Haiku will catch some interest from Asia regarding the lack of working input method for them.
Now a recipe to haikuports? ![]()
The recipe is ready, and I hope you will help me to post it on haikuports. ![]()
xaralx-recipe.zip
First thing I noticed is you used “master” in the recipe for source_uri, this should be fixed to use a commit checkout with srcGitRev, repology doesn’t mention Gentoo for this, but I guess it best suites media-gfx to be stored at haikuports, if you need help in getting setup for creating a PR, Fork haikuports repository · Begasus/haikuports Wiki · GitHub list a few steps how to begin.
Thank you. ![]()
Spsrht1.2.2 is a FLTK-based spreadsheet application.
To compile:
g++ $1 -g -Wall -I. -DLINUX=1 -I/usr/local/lib -I/usr/local/include/FL/images sprsht.cxx -o sprsht -L/usr/local/lib/lib -lfltk -L/usr/X11R6/lib -lX11 -lXext -lm
Is FLTK an effective enough toolkit for us to develop applications for Haiku?
These wont work on Haiku, we don’t follow that format, and are probably obsolete here.
FLTK should be fine, if not, please file a bug report at haikuports. ![]()
Ok, now
g++ -I. -DLINUX=1 sprsht.cxx -o sprsht -lfltk
works.
sprsht + FlWriter is the FLTK productive kit.
Will they ever be something helpful for us?
No one can answer that
it all depends if there is an audience for it.
There’s a programming language that I would like to have in Haiku.
In fact, we could have an older version that is 32-bit and the newer for 64-bit.
It’s the Euphoria programming language.
Euphoria is a powerful but easy-to-learn programming language. It has a simple syntax and structure with consistent rules, and is also easy to read. You can quickly, and with little effort, develop applications, big and small, for Windows, Unix variants (Linux, FreeBSD, …) and OS X.
Surprising to many, Euphoria is one of the fastest interpreted languages around however for more speed and ease of distribution Euphoria also includes an integrated Euphoria to C translator.
Euphoria provides subscript checking, uninitialized variable checking, garbage collection, and numerous other run-time checks, and is still extremely fast.
The old 3.1.1 32-bit version can be obtained from rapideuphoria.com.
The newer 64-bit versions, can be obtained from openeuphoria.org.
I did a non rigorous benchmark for running times and the results are these.
I didn’t test yet running the Euphoria code after translation to C, should be even faster.
there are atleast 4 users from india, so is there support for typing any indian languages? (hindi, bangla, etc)
Just chiming in to see if we can get a slightly newer rust version, 1.95 or so. I don’t know much about Rust and have never ported something as complex as an entire compiler/language before, but the software I’m trying to get running requires a just-so-newer version than whats in the depot.
I see there’s some activity by someone else on the IRC channel to get Rust 1.99 ported and added to HaikuPorts so that may happen.
No support for Devanagari script…many characters cannot be typed
what about others?
Refer to my other threads / posts regarding support to Devanagari, Hindi etc…pulkomandy has given detailed explanation…no developer who has an understanding of Indic languages to further work on this …maybe you can? I am not a developer, just an user
