we can have? please
thank you so much!
OF
I created recipes for gmime and balsa (albit without icon (no svg is supplied in the source)).
gmime builds and packages fine without patching, for balsa I used patches from Debian and Gentoo, not using webkit2gtk (canāt make configure seem to pick it up, there is still meson that I havenāt checked out).
I you donāt mind I can push those to haikuports (havenāt been able to connect to my gmail account, but I also havenāt used any email app on Haiku so far).
Not sure if you had any other patching aside for build errors done on your side?
That would be great! Push them to Haikuports, and Iāll take a look at what youāve done.
Gmail, I havenāt really looked at using Balsa.
Iām going back to a 6 day a week grind at work to help cover for a guy whoās having surgery. I 'll be doing that till mid Sept. So, any input that I have could be rather slow in coming.
Also, feel free to add an icon in your recipe. The one I use t is an online free icon that I converted. Iāve never been able to add an icon to an apps recipe.
I forgot to mention. Youāll need to edit the configure file in order to use webkit2gtk-4.1
Also for ldap, going through dependencies atm. Thanks on the pointer!
