Shurdown Script
Howdy!
I seem to remember there was a way to do this in Zeta and Haiku Alpha series. My forum search were not productive in locating good information to do it today.
What is the current preferred method to do to execute shutdown scripts in Haiku B5?
Do we have /shutdown directory like we have a /boot directory for the startup scripts/apps?
The reason is I have start-up bash scripts kicking off on boot-up. I also need to "gracefully’ shutdown the database servers and other processes during shutdown.
How do I do this now?
Ideally you would put whatever needs to run during the system and then turn off with the system in the aegeis of launch_daemon, it is analogous to what systemd would do on linux for services… sadly adding services is not that userfriendly yet :confused:
Is there adocumentation page for launch deamon somewhere
BeTips.net » Suchergebnisse » shutdown
BeSly
scripts are to place at: /boot/home/config/settings/boot/lauch
BeOS had these two shutdown scripts in /boot/home/config/settings/boot
Yeah, but: #4444: UserShutdown(Finish)Script not yet supported
Docs on launch_daemon in the HaikuBook.
Well phewy!
Ok…work-around will be redacting the startup scripts to perform checks for environment cleanup prior to server initialization.
Thanks everyone…good info.
