Setwep: command not found
I just installed r40074 (GCC 4 Hybrid) on my EeePC 701 and I want to connect to my wireless network. According to [1] I should just type
setwep /dev/net/atheroswifi/0 haikuwifi 0x3456789abc
to connect (with my SSID and key ofcourse), but this gives me
bash: setwep: command not found
How should I proceed from here to be able to connect to my wireless network?
[1] http://www.haiku-os.org/guides/daily-tasks/wireless
http://dev.haiku-os.org/changeset/39794
http://dev.haiku-os.org/changeset/39796
http://dev.haiku-os.org/changeset/39852
setwep was removed from image because now Haiku handles this directly. I don’t use wireless so can’t help anymore than this.
That wireless guide needs to be updated with new method!
Thank you for that information!
I cannot find where this “interfaces settings file” refered to in changeset 39796 is located. Any help here would be appreciated :slight_smile:
Edit: I found it. It was mentioned in one of Axel’s blog posts [2]. However, I did not get it to work. Will try some more in a few days when I return home.
[2] http://www.haiku-os.org/blog/axeld/2010-12-14_almost_not_there_yet
Well, I found out from another thread [3] that Haiku is unable to connect to ad-hoc networks, hence my problem.
[3] http://www.haiku-os.org/community/forum/haiku_asus_eee_pc_701_4g
