Screenshot function of Haiku (print button)
Is it possible to change the image format from png to bmp?
On PrintScreen key press, a window should open showing the screenshot preview and several options, the “Save As” popup menu letting you to change from PNG (the default format) to BMP if you want.
These settings are persistant, next time the BMP format will be already selected.
[quote=phoudoin]On PrintScreen key press, a window should open showing the screenshot preview and several options, the “Save As” popup menu letting you to change from PNG (the default format) to BMP if you want.
These settings are persistant, next time the BMP format will be already selected.[/quote]
Thanks for the tip, but i think i need a newer Haiku version, because this one don’t open a preview window, pressing the print key.
