Just wondering if the Roland SC-55 is supported in Haiku? connected via USB or via the SB game port? I did read the partial thread about features in Haiku, about the sound font missing etc, but just wondering if someone got this to work?
If it uses standard USB-Midi, it should show up as a MIDI device and be usable that way. You can then route MIDI data to it for example using PatchBay, or directly in applications that allow selecting the output by themselves (Sequitur probably does).
I’m not sure if the Sound Blaster game/MIDI port has a driver for the MIDI part yet.
