I’m I misremembering, or at one point following the introduction of the vector icon format, did we have the ability to scale any icon on the desktop to any arbitrary size?
No.
Programmatically, you can render an HVIF vector icon into a square BBitmap of whatever size you want.
… but many apps offering to play with icons size actually offer to size them from 16x16 up to 128x128. Tracker, Deskbar (even if it use a slider for that), LaunchBox…
Because they assumes it’s not a generic picture but an icon, and an icon is supposed to be a compact visual representation of a function, a ressource, a status, not consuming a large part of the screen.
But programmatically, it’s possible.
I wonder what desktop I’m thinking of then! Or perhaps we had the ability to set individual sizes at some point.
I just recall always making the trash can very large and appreciating how sharp it looked, but could have been something on X11
Maybe you refer @mmlr’s Tracker.NewFS, which was an alternative version of Tracker for BeOS R5 circa 2000-2002, which was supporting and using SVG for icons
Could well be, it’s hard to comprehend that so much time has passed since those final days of Be!
