Replicant in Deskbar tray
Strange behavior … if I enter a line with desklink in UserBootscript to add a deskbar replicant when the system boot the replicant is not added but if I launch UserBootscript after booting the replicant is properly added to the Deskbar tray
Haiku (Revision 35934)
Hi Giuseppe!
I can confirm your findings. There’s seemingly some timing issue involved. I inserted a “sleep 10” before the desklink entry in the UserBootscript to wait for 10 seconds and lo!, there’s the Replicant in the tray! Wanna file a bugreport?
IMHO, desklink-installed stuff should be permanent and should not require installation on every bootup. See #5367.
Regards,
Humdinger
